2008 Red Triangle and other signs
Discussion in 'Gen 2 Prius Main Forum' started by LikeAPrius, Mar 13, 2019.
  1. LikeAPrius
    LikeAPrius Member
    100
    26
    2019 Prius
    My friends Prius is showing these signs. You guys might a clue of what could be? Will try to get codes for it when I can.
    266k miles it was working fine until 4 months ago when it got that. Been sitting on his driveway ever since
  2. N3K X8
    N3K X8 New Member
    Maine
    Scan the vehicle, most likely hv battery
    52,803
    Can be many things, especially at that mileage
    Check the 12v and the inverter pump
  4. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    You can’t really tell from a picture what the problem is. You need to pull the codes with a Toyota capable scanner, not a generic OBD2 scanner.
  5. Graeme1949
    Graeme1949 Member
    51
    47
    Atlanta, GA
    Do you have any suggestions for such a scanner? I was about to get a mid-priced generic one when I saw this.
    -Graeme-
    2004 Prius with >190,000 miles.
    Sent ?.
  6. bisco
    52,803
    Tech stream, elm, torque, dr. Prius
  7. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Graeme,
    Do not get a mid-priced generic reader.
    Get these things,
    -cheap Android phone/tablet that can access wifi ($15-$50)
    -Torque Pro app ($6)
    - ELM 327 Bluetooth OBDII adaptor ($10-40)
    These will help you read and clear codes as well as check some of the hybrid specific info like HV Battery levels.
    I work on hybrids for a living and you can always give me a call for direct advice to get this car back on the road. 608-729-4082 Let's save this Prius!
    Graeme1949 likes this.
  8. LikeAPrius
    LikeAPrius Member
    100
    26
    2019 Prius
    Update
    It wasn’t the battery, some engine thing forgot what it was but the Prius is up and running again after a stop at repair shop ( Atomic Auto in Portland,OR)
  9. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    Thanks for the update.
    More detail would have been nice just to bring closure. Bit maybe you can find and post another time.
    I still highly suggest getting diagnostic tools if he wants to see some of the data himself.
  10. LikeAPrius
    LikeAPrius Member
    100
    26
    2019 Prius
    He will be bringing the the Prius over my place next week where I have a decent scanner that should work, for now the shop mentioned P0420 is showing up as well. This is odd, the car just passed emission tests a some months ago
