2008 Red triangle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JON KIRKEGAARD, Apr 25, 2026.
  1. JON KIRKEGAARD
    JON KIRKEGAARD Junior Member
    23
    Knoxville, Tn
    The Air Coniditoner is not working, hooked up the 134 gauges static pressure of 80 psi. I pulled the 20 Amp HEV fuse the engine started the fans came on, the AC compressor did not engauge, jumped the AC pressure switch the fans came on, no compressor reinstalled the HEV fuse. Got the red Triangle cleared the codes., hoping for a code reset but no. Now it will not start only goes from park to netural, will not set codes.
    Did i kill my HV invertor?
    I replaced the HV battery (new from Toytoa) 10 months ago. I have invertor coolant flow, the 3 way coolant switch connector is clean, HV connections are clean.
    Going to get the 12V battery tested scanner shows 11.6V.
    Help!!!
  2. ChapmanF
    18,993
    Does anything light on the dash now? The triangle perhaps?
  3. JON KIRKEGAARD
    23
    Knoxville, Tn
    The lights that are on are traction control, circle with ! in it, ABS, VSC, check engine, and tire sensor. The tire sensor is always on. The gas gauge is flashing on empty, but the car has 3/4 of a tank of gas, and of couse the red triangle. The scanner that I'm using is a CGSULIT SC880.
  4. ChapmanF
    18,993
    I'm not familiar with that particular scan tool, but scan tools that can't show you all the codes your Prius has are quite common.
    Because the triangle is on, it would be very helpful to find out the associated code(s), which will require getting access to another scan tool.
    The codes behind the brake/skid/abs lights can be retrieved without a scan tool, this way:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    You'll probably have at least 58 on the ((!)) light and/or 51 on the VSC light, both of which only tell you there are hybrid codes you need to retrieve, though you kind of already know that.
    From your symptoms, I wouldn't be surprised if P0AA6 with inf code 611 or 614 is among your hybrid-system codes, but it would be good to confirm that with a scan tool.
    PriusCamper likes this.
  5. JON KIRKEGAARD
    23
    Knoxville, Tn
    What third party scanner works best with a Gen 2?
  6. PriusCamper
    PriusCamper Senior Member
    13,428
    5,421
    Pacific Northwest, USA
    I like this one: Panlong OBD2 Scanner Bluetooth OBDII Diagnostic Tool Car Code Reader Turn Off... | eBay
    I use it for Dr. Prius app and Car Scanner app...
    Alternatively, you could consider a more expensive Autel device, which will give you almost all the features you get when you buy a Mini-VCI plug with cracked version of Toyota Techstream that you run on an old Window's laptop.
  7. Brian1954
    Brian1954 Senior Member
    2,668
    1,066
    South Central PA, USA
    Read this Gen 2 OBD2 App Review thread, https://priuschat.com/index.php?posts/3290690
    I recommend the Autel AP200 because it is capable of communicating with all the ECUs in the car, which means that it can read all the trouble codes. Most scanners can not read all the trouble codes (Dr Prius, Car Scanner, etc). The Autel AP200 is a Bluetooth OBD2 dongle that you use with an Autel app on your phone or tablet. It costs about $60 on Amazon.
  8. PriusCamper
    13,428
    5,421
    And for clarification for the readers, I think I read that the Autel AP2500 doesn't do as much for a Prius as Autel AP200? Is that correct? I think @ChapmanF said something about this once?
  9. Brian1954
    2,668
    1,066
    That is correct. The Autel AP200 can do more than the Autel AP2500.
  10. JON KIRKEGAARD
    23
    Knoxville, Tn
    The EBC, ABS, AND VSC are on a fast flash cycle, the air bag light is on an alternating fast flash cycle. The traction control and the check engine are on steady. The tire sensor light flashed these codes 21, 22, 23, 24, 25, 27
  11. ChapmanF
    18,993
    Really! And yet some of those lights are on when you go IG ON normally?
  12. JON KIRKEGAARD
    23
    Knoxville, Tn
    Correct, the only one that wasn't on during normal ING is the air bag.
    I have done 3 HV and 12V battery resets with no change in the master caution light status. It is parked on a small hill if the angle sensor is an issue, but it is the same hill that it is always parked on.
    I checked for A/C codes got a 42.
  13. JON KIRKEGAARD
    23
    Knoxville, Tn
    Autel AP200 has some very bad reviews, What have you folks heard about Linear Logic, LLC Scan Gauge 3 they have a lot of support for Toytoa Hybirds.
  14. ChapmanF
    18,993
    I have had Linear Logic's ScanGauge II around 16 years now, and I'm happy with the product and their support. It's what sits on my steering column day in and day out showing me things like coolant temperature that Toyota didn't think I'd want to know. I didn't really mind that all of the Toyota-specific parameters I wanted it to show me, I had to look up here on PriusChat and program in as, like, long hexadecimal strings using the four buttons on the front, because I only had to do that once. I haven't tried a ScanGauge III so I don't know how much easier they've made all that.
    It isn't what I use for diagnosis or repair of problems with the car. I have an AP200 for that.
    Viviparous and Brian1954 like this.
  15. JON KIRKEGAARD
    23
    Knoxville, Tn
    Purchaced a Creader Elite V3 Lexus and Toyota SW loaded
    The code are HV: P0A0D High voltage system interlock circuit high, current and history, A/C: B1442 Air inletdampercontrol servomotor, GWS: B1200 body ECU communication stop, B1207 Smart Key Ecu communication stop (have a non fuctional black label key), B1260 Transmission control ECU communication stop, B1271 Combo meter ECU communication stop TPMS: C2121, C2122, C2123, C2179
    I will be getting a new 12 Battery as it started the scann at 11.4v a was at 8.6v at the end of the scan.
  16. Brian1954
    2,668
    1,066
    Check the orange hybrid battery interlock and make sure it is installed correctly.
  17. PrimalPrius
    PrimalPrius Member
    138
    America
    This. It's not uncommon for people to forget that when reinstalling it, you must first rotate the "handle" and after that slide it. Lots of people forget to also slide it and end up with various codes and the car won't go into drive.
    But a low 12V alone will also give you an assortment of codes and the red triangle and inability to shift into drive.
  18. ChapmanF
    18,993
    P0A0D can also be about cover interlocks on the inverter, possibly disturbed for access to the HEV fuse mentioned in the OP.
    At least, I know there are such interlocks in gen 3. Assuming for gen 2 also.
    Brian1954 likes this.
  19. JON KIRKEGAARD
    23
    Knoxville, Tn
    :) o_O Thanks the shorting plug was not all of the way in. It is running now and it is back to P0037 bank 1 sensor 2 reading low, B1476 A/C inverter load system.
  20. Viviparous
    Viviparous Junior Member
    31
    Back in California
    2014 Prius v wagon
    We have had the same set-up. A ScanGauge II that sat on our Ford’s steering column for a decade. Now, that we sold the ScanGauge along with the Ford, we bought another ScanGauge 2 that will it sit on our Prius’s steering column. I will program it to show coolant temperature, inverter status, transmission temperature, etc. once I get used to the Prius. As far as an OBD reader, we already have an Autel AutoLink AL629 standalone unit, and we ordered a Veepeak dongle to work with Dr. Prius. We should probably order an Autel MaxiAP AP200 but we wonder: Because you can only specify one manufacturer, does that go with the phone or with an account on Autel? We wonder because we want to upgrade our phones and if the target software goes with the phone as well as the unit, then if we get a new phone, will we have to re-purchase the manufacturer-specific software?
