2008 - Replace Accelerator Pedal or ??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DavidinNevils, Feb 23, 2026.
  1. DavidinNevils
    DavidinNevils Junior Member
    42
    Georgia
    The shop is telling me that the codes say the accelerator pedal needs to be replaced in our 2008 'spare' Prius.
    He says there are dual controls, one a backup to the other, and when they go out of sync the whole assembly needs to be replaced. (Even thought it appears to be working fine.)
    Is it correct that the pedal can't be repaired - it just needs to be swapped-out?
    Other than Toyota, is there a reliable, and affordable, recommended source for a replacement?
    Thanks.
  2. ChapmanF
    19,054
    Please ask your shop for the actual, exact trouble codes they are seeing, and post those here. A trouble code is five characters, where the first is a P, C, B, or U, the next is a 0, 1, 2, or 3, and the rest can be any digit 0 through 9 or letter A through F.
    A Prius has sensors both on the accelerator pedal and on the throttle itself (two sensors, for redundancy, in each place), and there are codes about one and codes about the other, and they all look similar and they all have similar descriptions that start "throttle / pedal position sensor / switch", and people mix them up all the time. It's no fun replacing the wrong thing.
    Here is a post you can refer to for more information.
    Brian1954 likes this.
  3. JC91006
    16,939
    8,647
    Since this is rarely posted as a problem, I would think there would be plenty of used parts available. All will be somewhat reliable, due to the rare failure occurrences that are listed on this forum.
    In fact I might have one for sale LOL
  4. Hayslayer
    Hayslayer Active Member
    539
    331
    Pretty sure this has shown up several times previously and is always a misunderstanding of the DTC.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    X2 for having the actual trouble code(s).
    A (not uncommon) scenario is to have a P1121, which many "generic" scantools or google defines as a fault with throttle or accelerator position sensors.
    On a Gen 2 Prius, that (manufacturer specific) code points to a common fault with the coolant control valve.
  6. DavidinNevils
    42
    Georgia
    Just got this from our mechanic ... Pedal codes: P1116, P1150, P1121
  7. ChapmanF
    19,054
    Um, there's no connection between any of those codes and the accelerator pedal in a gen 2 Prius.
    P1116 is about the temperature of coolant coming out of the coolant heat storage system "thermos" not being as expected.
    P1150 means the car thinks the coolant heat storage system might have a clog preventing coolant flow.
    P1121 means the position sensor on the coolant control valve isn't responding as expected when the car tries to change the valve position.
    If the valve really isn't changing positions when it should, that could explain the P1150 and P1116 also. So, I would start by troubleshooting the P1121:
    https://attachments.priuschat.com/attachment-files/2019/12/178524_DTC_P1121.pdf
    ... at a shop that doesn't try to tell you these are pedal codes ....
    Brian1954 and Prodigyplace like this.
  8. DavidinNevils
    42
    Georgia
    I think he just accidentally sent me the wrong codes. I asked him to check and send the correct ones. I'll post them when he does.
  9. Hayslayer
    539
    331
    He did not send you the wrong codes. He sent you exactly what we were expecting, because we've seen it multiple times.
    Please see post #4.
    OR, let him replace all your pedal parts, then he'll probably want to swap the throttle body, and then you'll be complaining about spending a thousand bucks and still having the same codes.
    The cooling valve failure is VERY common on the gen 2.
    BiomedO1 likes this.
  10. DavidinNevils
    42
    Georgia
    Right now we're just replacing the Heater Coolant Flow Control Valve and the Inverter Cooler Water Pump. $132. in parts.
  11. Hayslayer
    539
    331
    You know the inverter cooling water pump and the flow control valve are two different cooling systems? They have no interaction with each other? Those codes have 0 to do with the inverter cooling system.
    If they're replacing the coolant pump just because they're in that area already doing the valve, for $132 in parts it sounds like they're using chinese counterfeit components.
  12. DavidinNevils
    42
    Georgia
    The parts are coming from Advance Auto - they pay parts, and his labor, to replace them if they fail.
  13. Hayslayer
    539
    331
    I'm very curious as to what they're actually installing, because inverter cooling pumps at advance are around $220 and the control valve is a bit less than a hundred if I remember correctly.
    Usually, a mech that buys from a parts store gets a discount, but then marks it up for the end user. $130 for what's normally $300 ish for a typical purchaser is a mighty good deal. Who is doing the work?
    Sure, they provide a replacement if it fails within warranty, but you eat the downtime. The best warranty is the one you never have to use.
  14. DavidinNevils
    42
    Georgia
    A very local, one-man-shop, mechanic. He's done a lot of work for us over several years - way better prices and quality of work than any of the shops in town. (We tried several of them - you never know if you're getting the rookie, the drunk/stoner, or a competent mechanic. They claim to be able to fix things - but we had to visit online groups, find information, and tell them how to fix them - or show them the youtube link. Thousands wasted in prior years on defective and unnecessary work.)
  15. ChapmanF
    19,054
    I admit I got a poor impression of him when he told you P1116, P1150, P1121 had anything to do with the pedal. But anyone can make a mistake. Maybe he's pretty good overall.
    Still needs to be smarter about where he looks stuff up, though.
    #15 ChapmanF, Feb 25, 2026
  16. DavidinNevils
    42
    Georgia
  17. ChapmanF
    19,054
    P1121, like all P1 codes, is manufacturer-defined, not standardized by SAE. The code can mean completely different things in different car models.
    The scan tool this guy is using just willy-nilly gloms together all the descriptions it knows for P1121 in any kind of car. There's some car out there where P1121 has to do with the throttle pedal, but that car ain't a Prius.
    The mechanic needs to know to look up manufacturer-defined codes in the right car's Repair Manual. (Or use a scan tool that, like Techstream, knows to show the right code description for the car you're looking at.)
    #17 ChapmanF, Feb 27, 2026
  18. DavidinNevils
    42
    Georgia
    Thanks! I shared that with him. I believe that all of the codes should now clear - because he's replaced that. (He's charging the 12v battery because it ran dead. We have a parasitic draw problem that we've traced to the door switches - and it's probably the hatch latch. Always a new adventure.)
  19. DavidinNevils
    42
    Georgia
    I have the accelerator but now that the two pumps have been replaced we're putting some miles on it in order to get fresh readings. Hopefully the pump replacements will have resolved the associated codes and I can return it. Thanks for the helpful input.
