1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
2008 Toyota Prius 280,000 engine problem.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kyle Becker, Apr 18, 2023.
  1. Kyle Becker
    Kyle Becker New Member
    Hartford, WI
    Check engine light, triangle danger light, Abs lights vsc light all on. I changed out all coils and plugs. I was driving today and when I would accelerate it felt like it was going to stall and was skipping. When it was idle it would shake my car. I am guessing it probably reached it’s time just seeing if you experts would know if it was a battery issue or a cheap fix? Thanks for your help.
  2. Tombukt2
    Tombukt2 Senior Member
    5,510
    967
    Durham NC
    And you change the plugs and coils because of the shaking while you had the plugs out you should have looked at them with a magnifying glass or touch them with your finger and touched your tongue and see if you smell the traces of coolant on any plug If so that's a giveaway that you've got a cylinder taking on coolant a head gasket leak.
  3. SFO
    SFO Senior Member
    5,245
    4,213
    Northern California
    Welcome to PriusChat!!
    Do you have any OBD2 codes worth posting?
    FYI : you're being moderated until you've posted 5 times.
Loading...
