2008 Toyota Prius piston soak
Discussion in 'Gen 2 Prius Main Forum' started by Jordanburch, Jul 29, 2018.
  1. Jordanburch
    Jordanburch Junior Member
    Hey guys
    Had high oil consumption 4 quarts in two months. I did the overnight piston soak with marvel mystery oil and changed the plugs and we're two weeks in and have had zero oil consumption. Just wanted to post my success.
    Jordan
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Welcome to Priuschat !!
    Glad to hear you're having success, and thank you for posting your piston soak experience.
    How many miles are on your vehicle?
    What oil type (dino/synth) and weight do you use?
    How did you remove the MMO after you were done letting it soak?
    On the average, what speed to do drive on the freeway / interstate?
    Was there a reason you chose MMO over something stronger?
    blaisep, m.wynn, Raytheeagle and 2 others like this.
  3. Mendel Leisk
    42,343
    How many miles in those two weeks?
    DLC82SV likes this.
  4. Jordanburch
    No it it cheap and I have used it in engines before with success
    Around 350 per week mileage.
    #4 Jordanburch, Jul 29, 2018
    SFO and Mendel Leisk like this.
  5. Mendel Leisk
    42,343
    If you mileage accumulation is pretty steady, that's steep consumption: somewhere around a quart every 700 miles. Which is still "acceptable", according to Toyota...:rolleyes:: (In the Owner's Manuals there's statement that a quart every 600 miles in the acceptable limit.)
    Perhaps Toyota should note this "feature" in their sales brochures. :whistle:
    You squirt a measured amount of MMO into each spark plug opening? How much?
    I'm thinking you could do this just before an oil change: put in the MMO and let it soak, crank the the engine over a turn or two (say with a socket on extension, reaching through the wheel well), then drain the oil, replace oil filter.
    Yeah, please post an update in a few more weeks: the more miles you pile on, the more accurately you can determine the oil consumption reduction. Sounds like a relatively simple procedure to do, btw.
    C Rider, padroo and PriusCamper like this.
  6. PriusCamper
    PriusCamper Senior Member
    13,455
    5,430
    Pacific Northwest, USA
    Marvel Mystery Oil... That stuff... Back in 92 my Mazda RX-7 Rotary engine had all the signs of blown seals... So I sold it to a guy who raced rotary engines for a few hundred bucks. He poured that stuff into the engine and drove the thing away. A very humbling experience. What is it about that stuff?
    ukiltmybrutha, blaisep and padroo like this.
  7. Jordanburch
    Iyou will need to change engine oil for sure. You will see tons of white smoke for a good thirty minutes but it will clear up even after changing oil. Don't hand crank it just try and start it. Hand cranking won't spit out the mmo like the starter will. It will not harm your engine if you just let the starter crank crank it right out. I don't think hand cranking is fast enough to get the oil out. You should try it it def helped me a lot!
    I'm not even sure man I guess is ester or some sort of chemical I don't know how to spell. It it super helpful in cleaning g out the engine. The oil after two weeks looks just as clean as when I put it in the car
    #7 Jordanburch, Jul 29, 2018
  8. padroo
    padroo Senior Member
    2,763
    2,253
    I had success with Marvel Mystery Oil in the past freeing stuck lifters on my wife's 1960 Buick.
    I makes good air tool oil also.
    05PreeUs likes this.
  9. Jordanburch
    I also use it in my air tools way better than standard oil
    05PreeUs and PriusCamper like this.
  10. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I do hope that sorts out any mechanically induced cause of the oil shortages.
    ukiltmybrutha likes this.
  11. Jordanburch
    So far so good. At this point I would have already consumed at least a quart or two. The level is exactly the same as when I put it in
    dpower, Prodigyplace, blaisep and 2 others like this.
  12. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Any more updates on your oil consumption?
  13. Jordanburch
    Still not consuming oil all. Is well these are great cars except for the Piston rings
    Skibob and SFO like this.
  14. Mendel Leisk
    42,343
    How many miles post-treatment now?
  15. Jordanburch
    I'm guessing about 3000-5000
  16. Prii0506
    Prii0506 New Member
    NYC
    I've been adding MMO during oil change, as per MMO's instructions: 20% replacement to oil, so that's about .75 quart or just about a quart for my 2005 Prius. I have not seen much success in stopping oil consumption. I am afraid of pouring liquid stuff where the spark plugs sit due to my "very expensive experience" where once my car engine was knocking and had to tow it to the dealership and $ 1100 repair later... it was water that had leaked thru the aging seals somehow. So if I understood this thread correct: a piston soak is where we pour MMO via the coils/spark plugs and let it sit there overnight?
    Then do we attempt to start it the next day by putting the spark plugs back in and drive normally? or do we attempt to start without the plugs to clear the MMO out? or should I use my oil pump to suck out MMO before starting?
    Original Owner of 2005 Prius
    2nd owner of 2006 Prius
    265,000+ miles and driving....
  17. padroo
    2,763
    2,253
    If you try to start the car with too much oil in the cylinder you will hydrolock the cylinder and bend a rod ruining your engine. Inspect each cylinder for liquid content, hopefully it soaked down by the rings and that is where you want it to go. On a normal car I would crank it over to be safe.
    Skibob and Prii0506 like this.
  18. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    100% true. Old Porsche 356’s had a bad habit of hydro lock if you didn’t close off the fuel valve on the gas tank. The tank was above the height of the carb and under the right conditions gas would partially fill a cylinder, someone hits the starter and boom, broken crank.
    I don’t think the OP ever mentioned how much he put in each cylinder. Either way personally I would suck out as much as I could before starting the engine. Whatever good it did would have occurred by the oil leaking past the rings I would guess.
    Prii0506 likes this.
  19. Jordanburch
    Hey Guys update! The car has been running really well. The oil consumption has been dramtically reduced. I used to consume about a quart a week and now only 1/16 of an inch on the dip stick. It did go up after soak, but I put in MMO and let it run and went back down again so im going to constantly run it with mmo. This fix has worked and it is about what six months later or so?
    SFO and Skibob like this.
  20. Skibob
    2,912
    1,505
    Northern California
    That’s great news. Are you putting the MMO in the fuel now? How much did you put in each cylinder to start?
