2008 Toyota Prius rear end sways over bumps
Discussion in 'Gen 2 Prius Main Forum' started by amjohnson, Aug 30, 2016.
  1. amjohnson
    amjohnson Junior Member
    77
    US
    I was hoping someone can answer this question for me I've realized in the past week or two that when I am slight Road and Perfections manhole covers and potholes my rear end feels like it's swsys a little my front end feels like it is just fine it's after the front hits the bumps the back end feels like it lets loose can someone tell me what the problem might be I have 70,000 miles on the car thank you
  2. amjohnson
    77
    US
    I should also add if you let go of the steering wheel it goes perfectly straight no pulling left or right
    51,108
    sounds like shocks/struts, but i'm no expert. how are the tyres?
  4. DadofHedgehog
    DadofHedgehog Active Member
    681
    282
    northern Virginia
    If your car has 80+ thousand miles, time for all new shocks whether they leak or not. OEM shocks just don't last much beyond 50+ thousand miles, no matter what the car, except that they deteriorate so slowly that it's imperceptible until they get really old and bad. It's not that much $$$ for new shocks , and not hard to do it yourself if you or your friends are tool-handy.
  5. DGH
    DGH Thread Terminator
    365
    93
    Wales, WI
    If you want a heart attack check out the dealer pricing for all four corners.
    bisco and DadofHedgehog like this.
  6. amjohnson
    77
    US
    Tires look fine no unnormal wear they have 10,000 miles on them
  7. garglo
    garglo Member
    99
    45
    Port St Lucie, FL
    2020 Prius Prime
  8. bisco
    51,108
    maybe you have a broken suspension part or worn bushings. if you can't diy, i would take it to a reputable suspension shop or toyota dealer and have them look around. maybe an anti sway bar would help, idk.
