2008, weird noise under hood, drivers side
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by les.warden, Apr 17, 2019.
  1. les.warden
    les.warden Junior Member
    22
    Central illinois
    2008 Prius. We purchased new. I have this strange noise under the hood, on the drivers side. Almost sounds like something trying to open, close, or engage then stopping, then retrying, etc. Over and over. I don’t know if it does it ALL the time, but definitely when I start it up. Always done maintenance on the car. Just had new struts, tires, plugs, oil and all filters changes. It was doing it before any of this though. It has 134,000 miles and still runs like a champ. I have a small video with the noise that I’m trying to figure out how to upload. I’ll upload soon as I figure that out. Any help in that area too is appreciated.
  2. JC91006
    16,933
    8,643
    It probably is a bad 3 way valve, it'll be much louder when you open the hood
    Raytheeagle likes this.
  3. les.warden
    22
    Central illinois
    Here’s the video
    iPhone
  4. les.warden
    22
    Central illinois
    It is louder when the hood is open. You can slightly hear it in the cabin.
    iPhone ?
  5. bisco
    52,789
    or else an hvac vent door
  6. les.warden
    22
    Central illinois
    Went on YouTube to search and ran across the replacement of a coolant valve. Seems to be in the same area of the noise. The video didn’t indicate a noise but said an error code (P112?) led them to the replacement. They also said there was a TSB on this very part.
    Assuming this is the part creating the noise and going bad, does the TSB mean Toyota should replace it at their expense?
    It seems like it’s costly to have them replace it but a major PIA to do it yourself.
    Maybe this is the valve being mentioned on my car??
  7. les.warden
    22
    Central illinois
    Can you expand on where a noise from that part might be heard?
  8. bisco
    52,789
    under the dashboard. the doors are motorized, but sometimes stick and keep trying to move.
    the valve is more likely though
    les.warden likes this.
  9. les.warden
    22
    Central illinois
    Finally decided: It’s a noise, could be the 3-way valve (probably). IF it is, $300-500 for shop to replace, seems a PIA to replace if I’m doing it (I have garage but not a shop). It’s NOT throwing any error codes and as far as I know, everything is working. Just the noise.
    So, based on the above, I think I’ll just forget it until it’s an issue. Unless someone’s got some feedback that makes me go..OH MY!!
  10. bisco
    52,789
    pretty sure it's not a problem unless you need heat
  11. John321
    John321 Senior Member
    1,502
    1,433
    Kentucky
    In our 08 Prius when the 3-way valve failed the vehicle sent a code that they valve wasn't in the position it thought it should be. This occurs mainly when the vehicle it turned off or turned on and the heat storage canister fluid is being transferred.
    Another possibility is that your brake actuator is beginning to fail. The actuator assy. is located on the firewall on the drivers side of the cabin. This assy. will begin making noises that you can almost set your watch by while you are driving the car or the car is in ready. The actuator is struggling to maintain correct brake pressure and is continually operating trying to maintain pressure. A good actuator will have to work only infrequently to maintain pressure.
    As the actuator continues to get worse it will eventually set codes when it can no longer maintain pressure.
    I have experience failure of both these item on my 08 and went ahead and replaced them myself. There are some good threads here on the forum detailing how to replace each of these items.
    #11 John321, Apr 17, 2019
  12. JC91006
    16,933
    8,643
    This noise will be gone after you replace the 3 way valve. A dealer will replace it if you are under California carb warranty, under 15 years and 150k miles. But I believe the dealer will still need the car to throw code p1121 before they'll address it
    Raytheeagle and les.warden like this.
  13. caravan2429
    caravan2429 Junior Member
    64
    Sandy, UT
    3-way coolant valve. Do you have P1121 code and Engine Check light on? I'm facing the same issue. I just ordered "Dorman 3-way valve", which is half of price of OEM one. However, there are bad reviews on any site, so I'm worrying how long it will last. It is on the way shipping......
  14. JC91006
    16,933
    8,643
    If you're going to save money by DIY, why go cheap? It's a bit of a tight fit to get this out.
    @jerrymildred has some ptsd from it
  15. les.warden
    22
    Central illinois
    No code, no check engine light. That’s why I’m saying forget it for now. Let us know how your replacement goes. I may do at a later time.
  16. JC91006
    16,933
    8,643
    There would be a code if check engine is on
  17. caravan2429
    64
    Sandy, UT
    Sometimes the engine check light comes on and off in intervals, I have no light on now but still sometimes randomly hear the sound from the coolant valve. You may check your code later. It is about time to replace it because of instability.
  18. caravan2429
    64
    Sandy, UT
    I would pay a mechanic to install it, though I know there are DIY videos on Youtube. It may be trickier to DIY with my little experience. I just want to try some cheap parts if it works well.
