2008 with 145k miles... change ATF?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Goolash, Apr 6, 2019.
  1. Goolash
    Goolash Junior Member
    36
    SE Idaho, USA
    As the title says, my 2008 has about 145k miles. The ATF and front differential oil have been regularly inspected, assuming the dealership has done what they claim on the receipts. Is it likely too late to start changing these fluids? Is there a way to tell without draining the systems?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    I’d drain it and refill it;).
    $40 for piece of mind:).
    Good luck and keep us posted (y).
    padroo likes this.
  3. padroo
    padroo Senior Member
    2,763
    2,253
    Like Ray says go ahead and change the ATF, it's not a big deal like a normal car. It's just a gear box, no bands, clutches or filter.
    Raytheeagle likes this.
    52,896
    not sure what front differential they are checking(n)
  5. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Hopefully not the one next to the blinker fluid:rolleyes:.
  6. Goolash
    36
    SE Idaho, USA
    I mention front differential oil because it is listed in the owner's manual. Did not make much sense to me, either. I'm assuming it is a copy/paste error. I have since seen that it is really referring to the transaxle, which in turn is part of the transmission assembly, thus changing one is changing both.
  7. Patrick Wong
    18,214
    6,530
    It is not too late, just drain and replace with 3.9 US quarts of Toyota ATF-WS.
