2008 with code P0117 and running strange
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by warlok, May 6, 2026.
  1. warlok
    warlok Junior Member
    25
    Casa Grande, AZ
    I left work today (42 mile drive, mostly freeway) and about 10 minutes after getting on the road, the triangle of death came on for less than a minute and then the check engine light came on. The hybrid battery drained to 1 bar and seemed to be running on just the engine, revving up and down to keep speed with lowered power. Got off the freeway and it settled into driving more normal and battery was charging up. Got back on freeway and same thing happened for the rest of my drive home. Turned off and it sounded like the engine cooling system was gurgling alot and there was a small amount of coolant below the radiator. Pretty sure it was from the overflow tube. Read code P0117 only. Do you think the coolant temp sensor could cause all that?
  2. Brian1954
    Brian1954 Senior Member
    2,658
    1,060
    South Central PA, USA
    No. The coolant temperature sensor will not cause any of the symptoms that you listed except for the check engine light to come on. The P0117 code is caused by very high coolant temperature or a short in the wires from the ECM to the temperature sensor. My guess is very hot engine coolant temperature. Code P0117 will not cause the red triangle of death (master warning light) to come on.
    What scanner are you using to read the trouble codes? Most scanners are not capable of reading hybrid trouble codes.
    The first thing I would do is check the coolant level in the radiator and in the plastic overflow bottle. Most people do not check the radiator, and they only check the overflow bottle. Make sure the coolant is cooled down before removing the radiator cap. Coolant should be full all the way up to the top. Low coolant will cause the engine to run hot and could cause the P0117 code.
  3. warlok
    25
    Casa Grande, AZ
    Well, I made the mistake of pulling the cap when it was still hot and lost about 1/2 gallon or more out of the radiator cap. So not sure how low it was. The overflow tank was only a bit low. I'm waiting to fill it back up until I see if I need to replace anything else.
    I have a newer cheap Autel AL319 and an older updated Innova 3100. I've never had a problem reading codes on the prius or any vehicle I've had.
  4. warlok
    25
    Casa Grande, AZ
    I was able to read all codes previously with the Innova about the inverter coolant pump, coolant valve, and when the hybrid battery went bad. I didnt try the Innova this time, just the Autel. I assumed it would be fine. I got the Autel to keep in the prius, just in case.
  5. Brian1954
    2,658
    1,060
    The Autel AL319 scanner is very basic. It is good for reading engine codes and emission readiness, but not much more than that. It can not read brake (ABS), hybrid codes, air bags, etc, etc. So, you probably were not able to read all the codes that were present. You should carry the Innova 3100 scanner in your Prius until the problem with the car is fixed..
  6. warlok
    25
    Casa Grande, AZ
    I cleared the codes before i posted here. I had no idea the Autel couldn't read hybrid codes. Thought a code is a code.. So I'll refill the coolant tomorrow and take it for a drive, not so far from home, and see what happens. I'll update after.
    Brian1954 likes this.
  7. BiomedO1
    BiomedO1 Senior Member
    4,517
    2,378
    Left Coast
    You my want to monitor your ECT as you go on your test drive to see how the cooling system is performing. Did you check your thermostat to see if it's opening up?
  8. warlok
    25
    Casa Grande, AZ
    Can I see the ECT on live data from the scanner? No idea if the T-stat is opening.
  9. Brian1954
    2,658
    1,060
    Yes
  10. warlok
    25
    Casa Grande, AZ
    How do i check to see if thermostat is opening?
  11. BiomedO1
    4,517
    2,378
    Left Coast
    squeeze and feel the upper radiator hose for flow, while the engine is running and above 190F. Wear thin gloves, so you don't burn your hands.
  12. warlok
    25
    Casa Grande, AZ
    Found the problem.. I ran to the closest autozone to see if their scanner would show anything I wasnt seeing. Had my live data on my scanner for the ride and the ECT went through the roof. I was looking to see if anything was amiss and where the thermostat housing was when I noticed I was looking at the belt tensioner with no belt on it... The belt was gone! Runs a bit warm with no water pump spinning. Installed a belt and its running perfect again. New coolant, no signs of any damage so far. Drove to work today and temp didnt get above 186. As of now, doesnt look like I cooked the engine. (Knocks on wood)..
    My last question is, why did I not get any indication while driving that the temp was that high? The triangle of death came on for less than a minute, no indication of high temp onbthe dashboard screen. The little car in the corner was even green. Wth?
    BiomedO1 and Brian1954 like this.
  13. BiomedO1
    4,517
    2,378
    Left Coast
    No coolant movement pass the temperature sensor, so no accurate temperature reading; while coolant was boiling next to the combustion chambers. All the other error lamps was the ECU throwing the car into fail-safe mode; because the ECU knew something was wrong.
  14. warlok
    25
    Casa Grande, AZ
    Well im glad I didn't cook the engine. 102 out today in AZ and it ran at 186-194 the whole way home. We can put this one to bed. Thanks for all your help. You guys rock \m/
  15. warlok
    25
    Casa Grande, AZ
    I may have jumped the gun on it being all good. Not running hot. But cooling system is pressurizing pretty bad. Pushing past the cap, over filling the overflow, and running out the overflow cap hose. Cheap radiator head gasket tester kit doesnt look good. Fluid turned green. ****..
