2008 with electrical gremlins and low mpg
Discussion in 'Gen 2 Prius Technical Discussion' started by Tony714, Jan 7, 2021.
  1. Tony714
    Tony714 Member
    110
    Orange County
    Hey Prius peeps. Picked up an ‘08 with 140k recently. Am now noticing things. After a few weeks of commuting 80+ miles a day, am getting 37-38 mpgs. Any ideas on what to remedy this?
    Also, the headlights shut off after I hit a bump but then can be switched back on. Sometimes one headlight will shut off. When headlights are functional, it’s very dim. There are no lights on the shift knob, radio buttons or around the touch screen.
    The mpgs may indicate poor upkeep by the former owner but the electrical gremlins are bugging the snot out of me.
    I had an ‘05 with 240k and these issues never came up. And that one I put an average of 100 miles per day for a year and no issues.
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,110
    2,011
    NJ-USA
    Things that can reduce mpg- wrong tires (not LRR) or low pressure, incorrect wheel alignment, weak hybrid battery, missing or damaged body panels or air dams, dragging brakes, engine /ICE problems (low compression, misfire, restricted exhaust, improper fuel trim/ control, weak thermostat), or possibly a wrong input of some kind that causes the ICE to run when it shouldn't (like a request for heat or A/C).
    Do you have halogen or HID headlights? Does the dimmer control for the dash illumination work? Do the tail lights work?
  3. Tony714
    Tony714 Member
    110
    Orange County
    I knew I made a general inquiry, so here goes. 17 inch wheels/tires, may need an alignment, no missing panels etc, hope it ain’t engine problems at 140k, and other than an audible buzz coming from the center of the dash ( in engine bay) that stays on while driving and about 40 seconds after shutdown, nothing else glaring.
    Pretty sure halogen, Dimmer does not work rear lights work when headlights shut off.
  4. PriusCamper
    PriusCamper Senior Member
    13,422
    5,418
    Pacific Northwest, USA
    You sure they're 17" wheels? Gen2 Prius comes standard with 15" wheels and the Touring version of Prius comes with 16" wheels which ends up causing slightly less MPG.
    So if you really have 17" wheels I'd say the car is running great and unless they're low profile 17" that's where you're losing all your MPG.
  5. Tony714
    Tony714 Member
    110
    Orange County
    My mistake. 16-inch, 205/56/16s that are properly inflated.
    Could the spark plugs and air filter alter mpgs that bad? Gonna reset the gas tank when I get a chance
  6. PriusCamper
    13,422
    5,418
    Resetting the 12v is indeed a good way to go... But in general 37-38mpg is within range of normal and boosting it higher is probably as easy new spark plugs, mass air flow sensor & throttle body cleaning, new air filter adding low rolling resistance tires at inflation PSI in the 40's... Also many with bad MPG have clogged cats due to getting their oil changed at oil change places that don't know that Prius hold less than 4 quarts and don't care if they add too much oil... And having your oil level above the full line not only kills your MPG in the short term it makes the inside of the engine real nasty, especially if the owner goes too long between oil changes and all that nasty travels out the exhaust pipe and can clog up the catalytic converter and because you're in California replacing that will cost near as much as you paid for the car.
  7. Tony714
    Tony714 Member
    110
    Orange County
    Ugh. Thanks for the good news on the cat. Yea the previous owner was a good dude but he was a clueless as one can be. Didn’t own it for very long and just did maintenance when needed.
  8. davecook89t
    davecook89t Senior Member
    1,093
    832
    Washington State, Florida
    If you have the Touring model, you also have HID headlights. The headlight issues you describe are most commonly associated with the HID bulbs. Replacing them with the quality OEM bulb would probably solve that.
    Edit: On second thought, if your car is a 2005, it couldn't be the Touring model, which was not available until 2007. It could still have HID headlights, though. Does it have factory fog lamps? That would mean the headlights are HID.
    2nd Edit: Scratch that, I see you are talking about an '08.
    #8 davecook89t, Jan 7, 2021
  9. PriusCamper
    13,422
    5,418
    Agreed... Those HID have unreliable ballasts that cost a fortune... It was a failed design. I converted a 2009 HID system to Halogen bulbs. Easy re-wiring job and you just buy the bulbs, the sockets and you need the most common cheap online lenses that bulb sockets mount on, which are less than a $100 for a pair. Here's links to bulbs and sockets I bought for less than $30:
    Genuine HELIOLITE Halogen 12V 9003 H4 Headlight Bulbs Hi-Low Beam | eBay
    https://www.ebay.com/itm/New-Headlight-Socket-for-Jeep-Wrangler-1955-2006-Dorman-84790/184437381933
    davecook89t likes this.
  10. Tony714
    Tony714 Member
    110
    Orange County
    Thanks for the info on the lights. Any step by step guide you can recommend or provide from memory?
  11. PriusCamper
    13,422
    5,418
    Just gotta google priuschat headlight conversions... There's lots of misinformaion on that subject though. For some reason people think you need to buy a high beam low beam switch. But it's way simpler than that. There's a wire that goes to the little motor in the HID and there's another wire that goes in behind where the bulb is and both these wires have a black ground wire. So you twist those two ground wires together and the other two wires are postive lead for high beam and low beam. The part I got stuck on is I was trying to wire from the car's wiring harness and the color coding on those is confusing so it's easier to tap into the wires after where the HID wires plug into the harness. The color coding isn't perfect that way, but easier.
  12. Toddwilks
    Toddwilks Active Member
    555
    177
    Whitehouse Station, NJ
    You can always just convert to LED and save yourself alot of hassle of buying new cheap non oem lenses and use what you already have. You can follow the guide here
  13. PriusCamper
    13,422
    5,418
    Does an LID Lens work with LED bulbs? I can tell you I know for certain that an LID lens will not work with a Halogen bulb because there's no clip to hold in place, nor receptacle to hold in place the Halogen bulb in an LID lens.
  14. AzWxGuy
    AzWxGuy Weather Guy
    1,078
    558
    Tucson, AZ
    2021 Prius
    My '08 would get between 42 and 48 mpg regularly on my daily 140 mile commute. Lower on the way down due to 2000 foot elevation change. It had HID headlights and fog lights, and I only had to replace one of the HID bulbs. Your electrical gremlins are a strong indicator of poor 12 V battery health. Do you know how old your 12 V battery is? It's that little motorcycle battery in the right-rear corner of the vehicle. Have that load tested for sure. A 12 V battery in need of recharging or replacement will cause a drop in mpg due to the charging circuit constantly trying to bring the battery up to spec. Can't think of a good reason for headlights turning off after a bump in the road. Loose connectors or corrosion/poor connections at the 12 V battery, which could cause poor recharging and also lead to electrical gremlins.
  15. Toddwilks
    555
    177
    In the video they show how to use the stock HID housing with the LED bulb so yes it does.
    iPhone ?
    PriusCamper likes this.
