2008 Won't start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ladydeadpool, Aug 1, 2017.
  1. ladydeadpool
    ladydeadpool New Member
    16
    Okay, I see what you're saying now. I'll double check it and see if it works. Thank you :)
  2. ladydeadpool
    16
    I checked the interlock and it is locked like the diagram shows.
  3. JC91006
    16,828
    8,601
    And still no start? Press the start button twice?
  4. ladydeadpool
    16
    Just the same as I described in #1. No luck :(
  5. JC91006
    16,828
    8,601
    This is very unusual, usually after you disconnect the battery, it'll reset and fault you may have and it'll start. I was pretty sure it was the interlock.....bummer
  6. ladydeadpool
    16
    I agree. I'll have it taken in tomorrow, hopefully it's nothing major. Thank you for all your help!
  7. JC91006
    16,828
    8,601
    You are positive you put the interlock in, flip the lever up, and then press downward to lock it in place?
  8. ladydeadpool
    16
    Yes, I undid the latch and redid it like the diagram showed just to make sure.
  9. Patrick Wong
    18,210
    6,514
    1. Check the 10A ETCS fuse in the main relay/fuse box next to the inverter (regarding P2118).
    2. P0A4C and P0A4D may point to a failure of the transaxle or a bad wiring harness.
