2009 headlights suddenly don't work on dim
Discussion in 'Gen 2 Prius Main Forum' started by Galane, Dec 6, 2022.
  1. Galane
    Galane Junior Member
    77
    24
    Idaho
    They don't work on dim at all. Standard lights, not HID. They do work on high.
  2. Tombukt2
    Tombukt2 Senior Member
    13,823
    2,509
    Durham NC
    Lo beams burnt??? Check H4 plug at bulbs see if you have 12 v at low beam wire ?
  3. Leadfoot J. McCoalroller
    8,275
    7,777
    Pennsylvania
    2018 Prius c
    Strong chance they're just burnt out.
    One probably went a while ago without telling anyone, and now the second one has joined it.
    Don't feel bad, it happens pretty often.
  4. Galane
    77
    24
    Idaho
    They're Silverstars only a few months old.
  5. Galane
    77
    24
    Idaho
  6. Leadfoot J. McCoalroller
    8,275
    7,777
    Pennsylvania
    2018 Prius c
    hmm those don't usually last as long as normal ones, but they usually last longer than "months."
    Time to bust out a voltmeter and start checking, I guess.
  7. Galane
    77
    24
    Idaho
    Will the high and low relays swap for testing?
  8. Leadfoot J. McCoalroller
    8,275
    7,777
    Pennsylvania
    2018 Prius c
    Couldn't tell ya, that model is different enough.
  9. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    ChapmanF says, "no," in the other where you're post the same line of enquiry.
