2009 INVERTER PUMP
Discussion in 'Gen 2 Prius Technical Discussion' started by RICH MOFFO, Jan 3, 2022.
  1. Tombukt2
    Tombukt2 Senior Member
    13,809
    2,504
    Durham NC
    Squeeze the hoses . Does the pump sound change when you squeeze the hose smartly?
    SM-A715F ?
  2. Tombukt2
    13,809
    2,504
    Durham NC
    What fuses feed the pump for the inverter just AM2 or is there another one?
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    Just AM2 through the inverter W/P relay. That relay is triggered by the power source control ecu (on IG2D ckt)
  4. turbo5spd-prius
    turbo5spd-prius Junior Member
    71
    United States
    I second this suggestion. I've change 2 of these pumps without completely flushing the coolant. No turbulence in the reservoir initially in both cases until I cycle squeezing the hose going into the pumps. The first pump was OEM. The second one that stopped working right was an Autozone unit. It just started working intermittently and only on at max power then. That one lasted nearly exactly one year. Hoping the Aisin one that replaced it does far better.
