2009 Prius 12v Battery Drain?
Discussion in 'Gen 2 Prius Technical Discussion' started by daisy555, Jan 14, 2019.
  1. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    Hi!
    It's been a while! This week Prius seemed to get stuck in accessory mode once when turning on. The brake, triangle, door and a few other dash lights were on but car wouldn't start. When I pressed power button again there was no response from it except that the orange light was still on. I don't even remember what I did to get the power button to respond. I think I put the fob in the ignition and was able to shut it off. Then everything worked fine for a few days.
    Tonight I tried stating car while running errands and the same thing happened again. This time I put fob in ignition and it didn't do anything and then I couldn't remove it. I panicked (as usual) and called dealership since they were closing. Manager told me to press the power button for 15 seconds. This shut the car off completely. I was able to remove fob but car wouldn't start and acted like battery was low/dead. AAA was able to charge batter and with in a few minutes said battery was 3/4 charged. When car turned on the info display said something about the transmission which totally freaked me out. I'm hoping this was just because the battery had drained and electrical stuff was rebooting.
    I do recall hearing a door alarm going off at different times over past couple of weeks when I exit car. I searched to be sure everything was shut off. It's an alarm that sounds like the one when lights are left on but I have lights set on auto. Could I have switched something on by accident that could be draining the battery? What kinds of things can drain battery besides the usual headlights or cabin lights? It was dark and no lights had been left on. If a door wasn't closed properly, I wouldn't have been able to lock the car.
    Any ideas? Maybe a faulty battery? I was reading on here that a battery can test that it's ok but still need to be replaced.
    Car has 145,000 miles on it. When I look at hybrid battery functions on display everything seems to be charging well.
    I'm calling dealer in the morning and having them check battery as well as codes.
    Long winded worrier...sorry.
    Thanks,
    Maria
  2. Moses Bruh
    Moses Bruh Member
    97
    29
    Your problem doesnt remind me of any of the common problems g2 prius has in the stickied thread, but you should check that out if you find it listed there. Have you tried checking out the engine oil and the coolent levels at the engine bay? Hopefully dealer can solve your problems.
  3. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    Hopefully all that is wrong is that your 12 V battery is past its prime. Yes, it can be tested, but testers for regular cars don't always do a good job testing whether a 12 V is good in a Prius. Given what you have said, I'd say your battery is currently in poor state, especially the fact it was ¾ charge after only a few minutes. Whether it can just be charged up or whether it needs to be replaced is difficult to say from a distance, but I would be leaning towards it needing to be replaced.
  4. daisy555
    1,729
    716
    CT
    Thanks so much for responding. I was just reading through a bunch of posts and saw someone with the identical issue even the same transmission error. He described the same door alarm sound too. Wish he had followed up with results.
    My hatch back area is filled with books etc to be donated and now realizing the battery is buried underneath all of this. : /
    Battery was last replaced 11/2014 so it's sounds like it's about time anyway.
    Hoping I can have them replace battery and pull codes. Hopefully won't be charged $100 diagnostic fee on top of all this.
    Thanks again!
  5. bisco
    52,879
    if you're getting the door chime, one of the doors likely isn't closing all the way. probably the hatch, could the books be interfering?
  6. padroo
    padroo Senior Member
    2,763
    2,253
    If the 12 V battery is bad the codes will be erased when the battery is changed and I would wait and see if they come back.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    And.....wait to see if it has a total failure to run next time ?
    Doesn't sound like a good plan to me.
  8. padroo
    2,763
    2,253
    I am just saying the codes will be cleared with the battery change, after the change if you have no check engine light why pay the $100.
    He doesn't really want to give them $100, I know I wouldn't. If he has any lights after the battery change then have it checked.
  9. daisy555
    1,729
    716
    CT
    Thank you so much for all the responses. Dealer was able to fit me in first thing this morning.
    Battery tested at 6 volts. They also checked for any codes without charging me $100 diagnostic fee. Service manager didn't want me driving off with a hidden issue beyond the battery. He agreed codes would have cleared if battery had died but last night (before AAA charge) cabin lights were still working. He felt confident there weren't any engine codes erased. Replaced battery for total of $291. So far I'm only a DIYer with cabin filter, engine filter and windshield wipers. : }
    I'm thinking maybe the hatch back was shut enough to keep the warning light off and possibly draining battery. Trying not to beat myself up since the battery was 4 yrs old.
    After all that I read last night.......I'm thinking way too much about the hybrid battery. : / It was checked last year. No symptoms and display shows all is working fine. I'm finally beyond the warranty which makes me very nervous knowing life expectancy is about 10 yrs.
    I'm flashing back to when all of you guys, so generous with your time, helped me maneuver the purchase of this wonderful car. It came with the confidence of a few more years of 150,000/10 yr hybrid warranty. I was hoping hybrid battery would fail during the warranty period. No such luck.
    Now that it's 2019 what are the most reliable options for replacing hybrid battery? If it ever goes, I want to be prepared as possible since these decisions usually need to be made quickly. My plan was to drive the car until there's a problem. I eventually want to trade up to a 2014/15. I guess trade in value now verses trade in value when hybrid system dies is irrelevant unless funds appear.
    I do love my 2009 Pria as she is! I remember test driving a 2010 and it wasn't as much fun to drive.
    Thanks again for your thoughts and suggestions.
    Maria
  10. bisco
    52,879
    if you can't diy, dealer is pretty much your only option. call around for prices.
    if you can find a mech who will swap the battery for you, you can get a new one for$1,600.
  11. daisy555
    1,729
    716
    CT
    Thanks, Bisco!
  12. Lisa Manis
    Lisa Manis Junior Member
    NM
    Sadly, the dash monitor inside died a year after I bought it used so I don't know the codes (or even what the codes are or where you'd find them???) --smart cookie, but Auto ignorant.
  13. bisco
    52,879
    there's a connection under the dash by the driver call obd. on board diagnostics. you hook a prius aware code scanner to it, andit gives you the trouble codes. you can post them here for help, google them for help, and sometimes you need to look in the service manual for help.
  14. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    Most reliable option for the HV battery is to get a new pack from Toyota.
    Price for the pack itself can range from $1650 to over $2000 plus tax. Installation might be $500 or so. Prices can vary wildly so it can pay to shop around.
    This assumes that there's no problems with the battery fan or corrosion damage to the battery ecu.
  15. mr_guy_mann
    4,120
    2,018
    NJ-USA
    You use a scantool to connect to the car's OnBoard Diagnostic port. (it's under the edge of the driver's dash by your right hand).
    Many scantools are not capable of "talking" to most of the 14-16 systems on a Gen2 Prius.
    Here's a thread that reviews several apps and devices that turn a smart phone into a scantool. Some of these are capable of scanning codes and data from all Prius systems.
    https://priuschat.com/index.php?posts/3290690
