2009 Prius 2nd gen roars at any speed
Discussion in 'Gen 2 Prius Technical Discussion' started by John Burden, Dec 24, 2018.
  1. John Burden
    John Burden New Member
    Indiana
    I bought a used 2009 Prius from a family member. Car roars at all speeds. I have changed both wheel bearings and both cv shafts and it still does it Help!
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Some questions:
    • How many miles on your Prius?
    • How long have you had it?
    • What is your mpg?
    • What does the hybrid battery state of charge donwhile the car is roaring?
    • Does it stay at the same pitch or does the pitch change?
    • How’s the engine oil level?
    Good luck and happy holidays(y).
  3. JC91006
    16,933
    8,643
    Check your tires for uneven wear
    Mendel Leisk and Raytheeagle like this.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Since he seems to think the noise is coming from that general area.
    Some brands/models of tires have noisy tread patterns too.
    Think off-road truck tires......only not quite as bad.
    And another wild idea:
    Does the noise only occur when the gas engine is running ??
    Like maybe the previous owner messed with the intake system.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    it’s not a quiet car. And it’s all tire.
    Try deflating all the tires substantially like to 22 lbs as a test and see if the noise characteristic changes.
    Keep in mind if your running LRR tires they have much harder rubber and when get old are really really noisey.
    Hopefully your not running Goodyear Integrities they are the worlds worst tire imho. Hard as a rock.
    What kind of tire are you running.
    TomB985 and Mendel Leisk like this.
  6. sam spade 2
    7,035
    2,804
    2017 Prius c
    BUT don't leave them like that for very long.
    LOW pressure is a good way to KILL tires.
    TomB985 likes this.
