2009 Prius - ABS Actuator Out / HV Battery harm?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by HiJoe, Nov 3, 2021.
  1. HiJoe
    HiJoe Junior Member
    Hawaii
    Thanks everyone for the help! I think we're in the clear for now and I learned quite a bit more about my 2009! Much appreciated!
    TheLastMojojomo likes this.
  2. TheLastMojojomo
    TheLastMojojomo Active Member
    232
    179
    US
    This is false, the ABS pump does not pull power from the HV Battery. It pulls power from the 12v.
    There is 0 risk of a bad ABS pump (which it sounds like you don't even have) damaging the HV Battery.
    Could it damage the 12v? Sure. A bad Accumulator pump will constantly cycle sometimes with the car off, which will discharge it. But there is ZERO risk for Hybrid Battery damage.
    As far as diagnosing a bad Accumulator... here is a Video showing my Brake Accumulator functioning normally. (0:17-0:35). This video is from my personal 09 Gen 2
    here is another Video showing Brake Accumulator failure. this video is from another Gen 2 Prius that shows Brake Accumulator failure with an in-depth description in the post of what's happening.
    Seems like you have things figured out but thought this info might be helpful.
