2009 Prius - advice for trickle charging / jumping
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by abbtt, Dec 22, 2015.
  1. abbtt
    abbtt New Member
    Maryland
    Hi all,
    I have an '09 Prius that is in fairly good shape, but had to sit idle for some months. initially we jumped the car with some success using the front battery connection, but even after driving it around for close to an hour, the battery did not hold it's charge. we've since replaced the battery with a new one, based on dealer recommendations, but the battery still is not able to hold it's charge very well.
    looking for some advice hear on perhaps using a trickle charge to feed into the battery. we tried doing this once on the old battery using a trickle hookup to the battery connection under the hood, but it didn't seem to work. is it best to do the trickle charge on the battery connection in the back? I did read on another post that the trickle charge may not provide enough for all the electronics in the Prius - is that true?
    anybody know if there might be another issue at play here that we should be looking at, and what that issue is?
    thanks in advance for all your help!
    abbtt
    52,849
    welcome! driving it doesn't charge it very well. trickle under the hood is fine. if it charges up to 12.5 or better, and holds there, you're good.
    if it doesn't get to 12.5, or won't hold there over time, it needs to be replaced. it is possible to get a defective battery, you need to test it.
    to test it, measure the voltage under the hood with everything off. then charge it, and wait a few hours after removing the charger for the surface charge to dissipate, and test it again.
    abbtt likes this.
  3. Mendel Leisk
    42,343
    Get a smart charger in the 3~4 amp range, one that'll run a complete charging gamut on the battery, ending up trickle charging, and can be left on indefinitely, if needed. Also pick up a decent digital multimeter, to measure battery voltage, giving you a rudimentary idea of the battery's state. And just read up a bit on the internet, lots of good info. There's no problem charging the battery at the under the hood jump point, btw.
    There's also meters available that'll give you a Cold Cranking Amp status on your battery. Solar BA5 is one example.
    This link has a table that outlines what voltage readings will mean. AGM batteries (used in the Prius) tend to be slightly higher:
    The 12volt Side of Life (Part 1)
  4. abbtt
    abbtt New Member
    Maryland
    thanks @bisco and @Mendel Leisk ! will have to look into the current battery's capacity and figure out what the deal is. might be a few days, but I'll keep you posted.
    thanks for the welcome!
  5. bisco
    52,849
    who installed the new battery, and what kind is it?
    one other thing to check would be the battery terminal connections and the ground wire to body connection. sometimes, when replacing the battery, these connections are not tightened or cleaned properly.
  6. abbtt
    abbtt New Member
    Maryland
    Dealership installed, would have to get back to you on type.
  7. bisco
    52,849
    it would be a toyota oem then, and under warranty. take it back and have them look at it.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    One thing that will help a little is if you have SKS key system you can disable it with a button under the steering wheel.
    That shuts off all the antenna's amplifier system around the car and will save a tiny bit of power but a Prius sitting for months will kill its 12 volt. Then you use the metal key in your fob. A Prius sitting for days time and time again will kill the little 12 volt battery. A slow loss of 12 volt battery power causes sulphation of the battery.
    Look into buying a battery tender with anti-sulphation mode. That will really help.
    Should be able to trickle charge from the front jump points no problem. If not your doing something wrong or the battery has already begun sulphation no matter how new it is.
    No matter what avoid jump starting a Prius at all costs. Its a quick and easy way to cause big damage to the electronics in the car.
    Especially jump starting a Prius stone cold dead 12. If you have to jump it don't have the donor car engine on and never ever use a AAA tow truck.
    Buy one of those little jump packs.
    Maybe install an RV type battery disconnect switch on the 12 volt? if you hardly drive your car or it sits idle alot a Prius is a poor choice of car. Its problematic in that situation.
  9. bisco
    52,849
    keep in mind the front jump terminal is metal on one side only.
  10. Mendel Leisk
    42,343
    Some clamps it doesn't matter, some it does.
  11. bisco
    52,849
  12. Metrolens
    Metrolens Member
    215
    Hi all, I have a 2005 Gen2 Prius, and just found I have a dead 12v, presumably because I left the trunk not well and fully closed.
    I have a battery charger (the BLACK+DECKER BM3B Fully Automatic 6V/12V Battery Charger/Maintainer with Cable Clamps and O-Ring Terminals).
    So, from the above posts, I gather I can simply trickle charge the 12v from the hood jump points without issue? Anything special I need to know before doing so? And, how will I know if my charger requires both sides of its positive clamp to make contact with metal?
    (My Prius is in a garage, and getting the trunk open to access the actual battery is going to be very difficult for reasons I don't need to get into here).
  13. Mendel Leisk
    42,343
    There is only a jump point (singular), which is where you make the positive connection, so you need to sort out somewhere to clamp the negative cable. You want to clamp to something "grounded", basically the car body and engine are part of the circuit, the negative side. Which is not hard: a good bet is bare metal on the engine, or any significant (and unpainted) bolt. It should also be secure, no risk of slipping off.
    A good way to test is with a multimeter set to Ohms (or continuity if it has it). Put one probe on a bare metal portion of the engine, and touch possible candidates with the other probe. If resistance drops to near-zero (or you get a beep with a continuity meter), you're ok.
    Another tester is a a sort-of screw driver with a light bulb, the end is a probe, and it has a wire with alligator clamp running off the handle. Clamp the wire to the positive jump point, then touch the probe to various bare metal candidates. If the light bulb in the handle lights up you're ok to use that point. Here's an example of the latter:
    To figure out if your clamp can be used either way, clamp it to something like a piece of wood, then check for continuity between the two jaws.
    Trumping all this, if you hook up the charger and doesn't complain, starts charging, you're ok. Just be very careful to always connect positive cable (typically red) to the jump point, and black to ground, not the reverse. Some chargers have safety feature to detect reversed hook up, but not all. So be careful.
    Metrolens likes this.
  14. Metrolens
    Metrolens Member
    215
    Thanks Mendel. I've become acquainted with the jump point, as I periodically use a digital multimeter to check the 12v voltage. Pretty sure there's a bolt about a foot north of the fusebox that will serve to attach the black/negative clamp.
    And actually there is a light that blinks on the charger when charging is underway. So that alone should tell me if current is flowing into the jump point, right?
  15. Metrolens
    Metrolens Member
    215
    So... a problem.
    My charger won't charge the 12v. Looking in the manual, it says it won't charge a battery that has dropped below 2 Volts. I just read my battery as having 1.96 Volts.
    Can anyone suggest a charger that might work here?
  16. Metrolens
    Metrolens Member
    215
    Called AAA, they jumpstarted at the jump points without a problem. I drove for 45 mins, had to stop for gas, so turned off the car. Car started up again with no problem. Back home now, and the trickle charger is attached and charging properly. I'll leave it charging overnight. So looks like I'm all good.
  17. edthefox5
    10,096
    4,837
    Clearwater, Florida
