2009 Prius Cargo Area floor is hot to the touch after 1 hour of running errands
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Judith L Woodall, Aug 11, 2018.
  1. Judith L Woodall
    Judith L Woodall Junior Member
    16
    Bellingham WA
    I
    I ran errands around town for about an hour (stop and go, not highway) and when I opened the hatch at home the cargo area floor was hot to the touch. I have had the car 9 1/2 years and have never noticed heat before. Is this normal?
    Sorry to ask such a stupid question but I do not drive the car much and might just not have noticed this before.
  2. hchu1
    hchu1 Active Member
    316
    127
    Houston, Tx.
    2014 Prius v wagon
    What part of the cargo area? Did you take the mat and deck cover off, take out the cargo box and check the spare tire area, the 12v aux battery area? With the cargo box out you will be able to see and feel the HV battery right behind the back seat.
    Judith L Woodall likes this.
  3. JC91006
    16,470
    8,386
    The cargo floor would be hot if the sun has been shining on it
    49,114
    welcome!
    the battery is way down below the floor/storage bin/spare tire. still, it is worth pulling everything out to look it over. you can drive like that and see how hot the battery case gets.
    might be a good time to check the battery cooling fan, intake grille and 12v area.
  5. Judith L Woodall
    16
    Bellingham WA
    I
    The deck cover in the middle was very warm to the touch and transferred a similar amount of heat to an all metal floor fan I just bought. I think the whole deck cover was warm but did not really check. I probably would not have noticed the heat if the metal fan was not warm (hot, or whatever) and if the box the fan came in fit the cargo area I might not have noticed at all.
    I did not remove the deck cover yesterday. My brain wasn't engaged until I had time to think about it. I put oven thermometers (lowest temp they report is 100 F) in the spare tire area and under the deck cover. *Today* I ran an errand (highway speed) and checked the thermometers both of which were not reporting a temperature and the hybrid battery was maybe slightly warm but just the smallest amount.
    I looked up the 12 volt battery in the owner's manual which seems to say it is in the spare tire area. I probably did notice it today but not really see it for what it is, if that makes sense. What I know about this car could dance on the head of a pin.
    Thank you
    I have a cover and use it.
    #5 Judith L Woodall, Aug 12, 2018
  6. Judith L Woodall
    16
    Bellingham WA
    I
    Today I put oven thermometers (lowest temp they report is 100 F) in the spare tire area and under the deck cover and at highway speeds nothing reported on the thermometers. Tomorrow I will try to reproduce yesterday's slow, hot trip letting the car spend 30 quality minutes in a very hot parking lot and see what the thermometers say. I used some science to figure out what 120 degrees feels like to the touch (outside of a Pyrex bowl of water) and think the deck cover pad was at least 120 degrees so the innards below that were probably hotter. I hope tomorrow to know more.
    Does "battery cooling fan, intake grille" refer to the hybrid battery? The hybrid battery was checked about two weeks ago and was reported to be in very good condition. I have not looked at the intake grill for the hybrid other than to make sure nothing was blocking it and have to assume the shop looked at the fan as well as the battery itself. I have not looked at the 12 volt battery but will look at it tomorrow. It is a Toyota OEM battery and is 3 1/2 years old. I have maintained this car very well and it has less than 12K miles on it over the 9 1/2 years I have owned it.
    Thank you
  7. bisco
    49,114
    what is the ambient temp there?
    the 12v is under the right rear corner triangular hatch floor piece, behind the wheel well.
  8. Judith L Woodall
    16
    Bellingham WA
    I
    Yesterday was 70(ish) and right now the temp is 73 degrees. The car was in a parking lot for maybe 30 minutes and was not particularly warm inside when I came out. The cargo area did not seem much warmer than the rest of the car when I rolled back the cargo area cover and put the metal fan in. I would have noticed if the car was very warm because I put my dog in first. Dog then fan.
    I am certain yesterday the cargo area floor was hot (warm) to the touch and radiating heat when I got home and removed the metal fan. (I really do not have a clue what the floor was doing when I put the fan in.) Heat transferred from the floor to the fan on the drive home (2 miles) on slow stop and go surface streets. The fan was much hotter than ambient and several cardboard boxes in the cargo area. I think that makes sense.
    I have 2 oven thermometers in the car (0 in my oven) which I will check and recheck every time I remember to check and recheck them. I will update this thread with relevant information.
    If anyone has a Prius and has seen anything similar please share or keep asking questions. A light bulb somewhere might click on!
    Thank you
  9. bisco
    49,114
    i have never seen anyone mention this.
  10. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,784
    2017 Prius c
    I think it is not unusual for it to feel "hot to the touch" or "very warm".
    There might be spots on the floor of the passenger compartment where you could notice the same thing.
    It is more likely to be noticeable when driving slow.
    The cause I am talking about is the exhaust system.
    Unless you want to crawl under and inspect it yourself, I suggest that you go to a dealer or muffler shop to have them put it up on a rack and inspect it for missing or out of place exhaust parts or shields.........just to help put your mind at ease.
    You also should have the battery cooling system (fan and duct work) checked and cleaned.
    And then stop worrying about it. (y)
    It probably has been like that for 9 years and you just recently noticed it.
  11. Judith L Woodall
    16
    Bellingham WA
    I
    Thank you
  12. Judith L Woodall
    16
    Bellingham WA
    I
    "might be [warm] spots on the floor of the passenger compartment" I only noticed heat radiating from the cargo area floor because the metal object on it was warm to the touch. I would never notice a warm spot on the floor of the passenger compartment. I will try to notice such things. It's also probably a good bet that the muffler on a 9 1/2 year old car with only 12 K miles has not been looked at.
    I will have both the muffler and hybrid (?) battery cooling system checked.
    Don't know what I can do about worrying...
    Thank you
