2009 Prius CEL P0303 help.
Discussion in 'Gen 2 Prius Main Forum' started by Kaptainkid1, May 28, 2020.
  1. Kaptainkid1
    Kaptainkid1 Active Member
    308
    248
    Los Angeles
    I pulled the CEL code and code reader spits out P0303 cylinder 3 misfire.
    History : At 160k I changed the spark plugs with OEM toyota plug.
    180k
    Drive really rough and check engine light is on.
    Clear code and pulled off #3 ignition coil and switch it with #2 coil. Ran car around the block and noticed ODBII reader and another check engine light P0303 again. Car still running rough and checked the forum and found out could be #3 injectors.
    Going to buy a set of new injectors but wanted the forum's opinion could this be the problem?
    SM-J737T1 ?
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Where did you buy the plugs from and what brand are they? There have been reports of fake NGK plugs being sold on E-Bay.
    Kaptainkid1 and SFO like this.
  3. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Skibob likes this.
  4. Kaptainkid1
    308
    248
    Los Angeles
    I fixed the problem by troubling shooting all the possible out comes. I swapped the coils drove around the block and got P0303 error code.
    I swapped Injectors and drove around the block and P0303 error code again.
    I read long ago that ebay has sellers who sold fake NGK plugs and decided to pull the plugs out. Even though I only drove 20,000 miles on them. Yup the plugs gaps we're way out of spec. 1.4mm. Man I was pissed off. I keep my old plugs and clean them up. Put the old one back in and now I have 4 fake plugs. People beware of fake parts! It's hard to spot. These even came in Toyota Genuine Parts box. See in photos.
    How to spot a fake:
    20200528_183042.jpg 20200528_183017.jpg 20200528_180050.jpg 20200528_173230.jpg
    SM-J737T1 ?
  5. Kaptainkid1
    308
    248
    Los Angeles
    Here is how to spot a fake Denso plug.
    SM-J737T1 ?
  6. Skibob
    2,912
    1,505
    Northern California
    I never go with Denso plugs. Why run with the second string when you can go with the varsity team (NGK)
  7. dolj
    dolj Senior Member
    8,646
    4,398
    Wellington, New Zealand
    DENSO Corporation is a well-established spin-off of Toyota Motor Corporation (TMC), it is Japan's leading producer of automobile components and the world's fourth largest. As the second-largest member of the Toyota Group, more than half of DENSO's products go to Toyota Motor Corporation (TMC), which owns better than 20 percent of DENSO stock.
    Considering this, I would have thought DENSO plugs would be the plug of choice for a Toyota, not second string.
    Kaptainkid1 likes this.
