2009 Prius Electronic Braking Warning Light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by skarim, Nov 27, 2012.
  1. skarim
    skarim Junior Member
    Hi ,
    I have a 2009 with 34,000 miles.
    About 3 times in the last month or so, the amber electronic braking warning light has come on, then turned off by itself a couple of days later. After the second time, I brought it to the dealer, but they said that no codes were set off and they couldn't find any problem.
    Has this happened to anyone before, or know what may be the issue?
    Thanks,
    SK
  2. Patrick Wong
    18,210
    6,517
    How about taking a sharp photo of the warning light(s) next time it(they) appear(s) so that we can see exactly which light(s) you are referring to.
    [email protected] likes this.
  3. skarim
    Here is a photo
    Thanks for the replies.
  4. archae86
    archae86 Member
    153
    24
    Albuquerque, NM
    tire pressure warning, not a brake problem.
  5. Patrick Wong
    18,210
    6,517
    I agree. A low tire pressure warning is not going to set a DTC.
    Check the tire pressure on all four tires and if necessary reset the tire warning system for the pressure that you use. Consult the owner's manual if necessary to learn about this process.
  6. KJ Fitz
    KJ Fitz Junior Member
    55
    Guam
    Also, excessively low pressure in the spare will trip that light on. I discovered mine was 30 PSI, aired it up, light went right out!
  7. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Priuses in the US do not have a sensor in the spare tire. But it sure is a good idea to check it regularly.
    My friend's RAV4 has a sensor in the spare which would light up on cold days and it bugged him to no end until I hooked up my Mini VCI and found the fifth sensor in the spare.
  8. Mendel Leisk
    42,345
    You should be able to tell by just looking at the valve stem on the spare, if it has tpms sensor or not. TPMS equipped valve is metal, and regular valve is black rubber.
  9. Mendel Leisk
    42,345
    Is your spare perhaps a full-size, or compact? If full-size, then it is likely to have the sensor.
