2009 Prius - getting 28 MPG
Discussion in 'Gen 2 Prius Fuel Economy' started by Stephenjn, Dec 28, 2017.
  1. Stephenjn
    Stephenjn New Member
    Boise, Idaho
    I need help. I have been reading the other fuel mileage threads, but am lost. I purchased a 2009 Prius about 8 months ago (third owner) for use as my primary vehicle, and to be used on paper routes I throw. I was averaging about 33-38 mpg, which I thought was lousy, but so much better than my previous non-hybrid. I put the mileage off to the paper routes. I fueled my car at Chevron, or Costco, because they had gas additives. When I did not, I got the lower gas mileage. I have recently started suffering mpg. I had the spark plugs and air filters (engine and cabin) changed, and used a fuel cleaner additive to clean the fuel system. No effect. I then did a "recommended" throttle bottle cleaning at the dealership. Still getting horrendous mileage. 26-28 MPG. One thing I think might be affecting it is the touch pad display is working intermittently on my car, and I struggle to get it off of A/C, though it is off 90% of the time. I have never had a hybrid before, so do not know what to do next. Suggestions? Prayers?
    52,848
    cold weather (assume that's boise) and winter gas formulation are natural mpg killers, up to 20%.
    what are you setting the heat at? not sure what you mean by a/c, it's december.
    pump your tires up to 42f/40r and keep an eye on them.
    check your oil level, and air and cabin filters.
  3. Stephenjn
    Boise, Idaho
    Thanks for responding. Oil level is perfect and recently changed, air filters are brand new. A/C is air conditioning. (Sorry). I have my Auto Air Conditioning off, Air Conditioning off, and the heater on full blast on defrost. I set my tires to 40 psi, and have checked them. Also went in for a rotation and had the shop verify psi. I track my mpg with an app called Fuel Buddy, and on December 3rd (in Boise, Idaho) registered 29.93 mpg. I had a couple of fill ups run me in the low to mid 30's, then hit 27.77 mpg on 13 Dec. That's when I had the spark plugs and air filters changed. A week later was the Throttle Body maintenance at the dealership. I hit a low of 26.66 mpg on 19 Dec, then 33.15 on 22 Dec, then 28.52 on the 27th. I am all over the place on MPG, but feel there is NO WAY I should be in the 20's. Or am I wrong? I am a newbie....
  4. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    I’m not familiar with all the different versions of the Prius, but the defroster might be causing the gas engine to run full time?
    Data Daedalus likes this.
  5. Stephenjn
    Boise, Idaho
    That made me do a Google..... apparently the defroster "may" use the same compressor as the air conditioner, but I need to do further research on it. A good direction to run in.... thanks.
  6. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    You may need a new 12V battery. Also this is in the wrong forum.
  7. bisco
    52,848
    yes, it might come on to dehumidify. 20's is a bit low, even for winter. tell us about your paper route; miles, starts and stops, average speed, etc.
  8. bisco
    52,848
    how many miles on her?
  9. jaqueh
    341
    199
    San Francisco
    Check out this entire page.
  10. Stephenjn
    Boise, Idaho
    Is was the forum it put me in (see "New member"... LOL) Can you assist me/tell me how to move it to the proper forum?
  11. Stephenjn
    Boise, Idaho
    I have been. I appreciate the suggestion.
  12. bisco
    52,848
    click on the report button on your original post and ask the mods to move it.
  13. jaqueh
    341
    199
    San Francisco
    Ah ok. Well usually the culprits are tire pressure, tire type, 12V battery, or main traction battery. Also weather and fuel blend, but I usually don't buy those arguments for such poor mileage.
    Also, how do you drive? If you brake very suddenly, you will get very poor mileage. Make sure you look up pulse and glide. That might dramatically improve your MPG without making you any slower of a driver.
  14. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    It is likely cold in Boise in December.
    December Weather for Boise, ID | Weather Underground
    Hints of days where the high was 23 F and the low was 8 F.
    Your Prius will not get as good of gas mileage when cold as when it is 80 F.
    1) All cars do worse in cold weather, oil and lubricaticants are thicker, roads are slipperier,air is denser, etc.
    2) All cars do worse when they are cold, they are programmed to run richer, they need to warm up to get better emissions, the driver runs more heater, etc.
    3) A Prius in particular does worse in cold, it turns off less at idle to keep heat to the driver, it runs the engine longer to get good emissions, Battery chemistry changes with tempurature, you are more likely to have headlights on, etc.
    What can you do to combat cold? Engine Block heater, cover radiator grill, heated garage, move south, etc.
    Engine Block Heater for 2004-2009 Toyota Prius - PriusChat Shop
  15. bisco
    52,848
    see post #2.
  16. jaqueh
    341
    199
    San Francisco
    Cold weather wouldn't make it go to 25mpg though. I really do think it's the 12V.
  17. Stephenjn
    Boise, Idaho
    124,350 miles. My paper routes total about 32 miles. Constant stopping and starting, with plenty of u-turns thrown in. Average speed about 10-15 mph. I throw 245 papers, so consider that about 225 stops and starts in a three hour period.
  18. bisco
    52,848
    getting a car moving from a stop uses the most amount of energy. that can be a big mpg factor.
    Stephenjn and jaqueh like this.
  19. jaqueh
    341
    199
    San Francisco
    Try starting and braking much more smoothly than you're currently doing. Check this out.
    When my family first got our '07, we drove it like we would any other car. That is wrong. With the older Prius, make sure you adjust your driving style and especially learn how to tell when the friction brakes make contact so you can prolong regen braking.
  20. bisco
    52,848
    a good test is to reset the meter, and take it on a long drive under varied condones and see what mpg's she returns.
    jaqueh likes this.
