2009 Prius - Issues - Florida Mechanic?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jk823, Sep 29, 2025.
  1. jk823
    jk823 Member
    100
    Los Angeles CA
    Hi!
    Had the dreaded red triangle show up on my 2009 Prius dash over the weekend. Brought the car to a trusted mechanic who printed the error codes - but said he didn't know enough about the Gen 2 Prius to suggest a course of action. Does anyone here have a trusted Prius mechanic in Orlando/Winter Park, Fl? The codes were at least:
    P1116
    P0A0F
    C0200
    C0205
    C1241
    (He only texted me the first page - it says 15 error codes were reportsed, but P0A0F appears numerous times (under "HV ECU - Current Codes" and "HV ECU - History Codes" and Cruise Control Curent codes and Cruise Control Hisotry Codes, for example.)
    Would love any help!
    John
  2. Prodigyplace
    12,708
    11,847
    Central Virginia
  3. PriusCamper
    PriusCamper Senior Member
    13,345
    5,395
    Pacific Northwest, USA
    Some of those codes occured long ago and it'd be better to focus on the codes that return. Basically if you buy one of these $20 devices: www.ebay.com/itm/265484403768 you can use it to connect to your phone and read and clear error codes, via Dr Prius app, Car Scanner (ELM) app and others. That way you don't have to pay the mechanic to do this. Also these easy to use devices can sometimes be the difference between making it home as planned or being stuck on the side of the road waiting for a tow truck.
    And once you start sending us screenshots of the error codes that return we can walk your through all the options that come up when deciding to repair or not to repair or how to repair.
  4. jk823
    jk823 Member
    100
    Los Angeles CA
    Well, right now that red triangle with the exclamation is up. On saturday when I went to start the car it also had "VSC" lit up and one that was an orange circle with the an exclamation mark in it. The low tire pressure has been blinking too.
    Can't help but feel like after 16 years, the car is on its last legs. :(
  5. ColoradoBoo
    ColoradoBoo Senior Member
    1,323
    939
    Monument, Colorado USA
    The hybrid battery may need to be replaced but I've seen them as cheap as $1,400 while the average is around $2,000 so, if everything else is okay, may be worth the investment to keep her running!!! (New and even used vehicles, these days, have insane prices.)
  6. saneesh8
    saneesh8 Member
    228
    Allen, TX
    Seems none of those error codes pointing to hybrid battery? is there any corrosion in the 12V battery connection ?
    PriusCamper likes this.
  7. Tombukt2
    Tombukt2 Senior Member
    13,765
    2,491
    Durham NC
    Nope you're probably in good shape for another 10 years actually . Batteries do get replaced but if lasted long enough some one mite replace thee car
  8. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    None of the codes implicate the hybrid vehicle (HV) battery.
    P1116 is telling you about the temperature sensor on the outlet side of the CHRS (coolant heat recovery system) tank.
    P0A0F is telling you that the engine was unable to start. One possible cause is running out of fuel.
    C0200 is telling you about a problem with the RH speed sensor circuit.
    C0205 is telling you about a problem with the LH speed sensor circuit.
    For both of these codes, there are 12 sub-codes (aka detail codes or INF codes). These are found in the freeze frame data and would be helpful to narrow down the area of concern.
    C1241 is telling you about a problem with the power source voltage arriving at the skid control ECU. It could be abnormally high or abnormally low. Checking the 12-volt system to make sure it is delivering voltage in the 10.5 to 14.4 volt range would be reasonable. If that is okay, working out why either the voltage arriving at the skid control ECU dropped or the voltage for the ABS NO. 1, ABS NO. 2 relay operation dropped, is next on the list.
    There is nothing big in all these codes, just methodical troubleshooting until you find the problem.
    Having recorded these DTCs, you should have your mechanic clear all codes and see which, if any, return and focus on those.
    Prodigyplace likes this.
