2009 Prius No Heat + P1121
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cybertlc, Mar 24, 2014.
  1. cybertlc
    cybertlc New Member
    Rochester, Minnesota
    Two weeks ago my CEL came on and the code was P1121. I checked the coolant level and everything seemed fine, so I figured I'd take it in soon.
    This week, my heater isn't working - it blows fine, but it is ice cold air. I again checked the coolant level and topped off the overflow, and nothing.
    Is the P1121 error related to the heating issue? Thoughts on this???
  2. Patrick Wong
    18,210
    6,517
    Check the coolant level in the radiator itself, not just the overflow reservoir. You need to remove the large black plastic panel over the radiator to access the radiator cap.
    DTC P1121 means that the engine coolant flow valve is stuck. That valve routes engine coolant between the cabin heater core and the coolant heat recovery canister. If the valve is stuck in the wrong position that would explain why the cabin heater is not working.
  3. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    When my coolant valve stuck, it was due to a low coolant level. The coolant acts as a lubricant for the valve. After a top-off of the coolant (it was low due to air bubbles left in when the coolant was drained/refilled), the valve loosened up. That was 155k miles ago and no further problems with the valve. I hope that you have the same experience,
    JeffD
