2009 Prius No Start Has Electrical Power after ABS actuator replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Drew Carfix, Feb 13, 2025.
  1. Drew Carfix
    Drew Carfix New Member
    Edwardsville Pennsylvania
    SE
    2009 Prius. After disconnecting regular battery, hybrid battery, and inverter to replace abs brake actuator and reassembling everything now the vehicle will not start. It has electrical power but I did note shifter will only go from park to neutral. The vehicle is still storing codes related to the brake actuator. Thank you all for this forum any suggestions would be appreciated
  2. PriusCamper
    PriusCamper Senior Member
    13,451
    5,430
    Pacific Northwest, USA
    Most common mistake people make after a system shut down like this is not fully locking in the orange safety plug and the clearing the error code that comes up when the orange saftey plug isn't full locked into place.
    Brian1954 likes this.
  3. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Is the "ready" sign on the dashboard?
    Can you take photos or video of the process when you start the car?
  4. Drew Carfix
    SE
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    What scantool are you using? What codes for the brake system are present? What codes for the hybrid system are present?
  6. Drew Carfix
    SE
    Scan tool is Snap On Solus Edge and the codes stored are C1203, C1252, C1256, C1345, C1392, P0A0D, and B1421.
  7. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    What PriusCamper poster in post #2. For some reason, a lot of people do not do step 3.
  8. mr_guy_mann
    4,113
    2,011
    NJ-USA
    Did these codes set after replacing the actuator? (Did you clear codes at any point?) Did you put a charger on the 12V battery and perform the full "actuator replacement" brake system bleed with the scantool? Did you perform the brake system relearn - initializations with the scantool? Did you install a new or used actuator?
    C1203 can mean "hey the hybrid control ecu has codes" (like P0A0D).
    C1252 (pump run time too long) & C1256 (accumulator pressure low) are often set when the actuator has an internal leak - & needs to be replaced. Or might result if there's a bunch of air in the system.
    C1345 means you have to perform the linear solenoid valve offset relearn.
    C1392 is the same for the stroke sensor zero point calibration.
    B1421 sets whenever there isn't strong sunlight shining on the HVAC solar sensor on the dashboard.
  9. ChapmanF
    19,009
    Hmm. Maybe C1203 can crop up in a situation like that? It's not like C1259 and C1310, the codes that actually mean "hey the hybrid control ecu has codes".
    My understanding of C1203 is it means something more like "hey I'm a new skid ECU (or new to this car, or lost my memory and think I'm new) and I tried introducing myself to the HV control ECU and we're not getting along."
    But maybe if the HV control ECU has codes of its own, it's saying "hey I'm busy here, go away" and that's why they're not getting along.
