2009 Prius No start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TheGMann, Jun 26, 2017.
  1. TheGMann
    TheGMann Junior Member
    wisconsin
    Need No Start Help. Prius 2009
    Went out to start. Nothing. Door open light works, Shows the no key symbol. Otherwise blank dash But nothing happens when I press power.
    Things I tried:
    Insert fob in dash and the no key light goes out, but still nothing, no dash nothing
    Check rear Battery 12.2V
    Main Bat 215 V (check all cells OK)
    Only other odd thing was the alarm would go off. I can use the fob to turn off. Also the fob does lock and unlock the doors
    Any ideas?
    Thanks
  2. JC91006
    16,936
    8,647
    Why did you check the hv battery?
    You probably didn't lock in the orange interlock switch. Lock it like this and it'll start
    52,863
    12.2v is low for the 12v battery.
  4. TheGMann
    wisconsin
    Charged the 12v Battery to full charge. No change.
    Could it be the FOB? I have only 1 .
  5. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    I would disconnect 12V for 30 seconds and reboot.
    If that doesn't work check fuses paying special attention to AM2 fuse
    I'm curious why you questioned the traction battery, have you done some recent work with it?
  6. TheGMann
    wisconsin
    Progress - sort of. Disassembled the FOB and cleaned the board up. Now the the dash lights up with red triangle, and brake light lit, Power button goes to orange.
    I hear a click when I depress the brake
    Now it shifts to neutral only.
    Also when I insert the fob into the receiver. The dash will not light up
    How do I check the brake switch?
  7. TheGMann
    wisconsin
    As for the traction battery. I haven't done anything with it, but on another prius that had some bad cells and it acted really weird so I wanted to check it out
  8. JC91006
    16,936
    8,647
    Are you sure the orange interlock is locked into place? As stated in post #2?
    Try jump starting it and see if it'll start.
  9. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Can you get the Climate Control or Radio systems to work?
