2009 Prius - Revving sound??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by daisy555, Mar 12, 2022.
  1. bisco
    52,789
    that's good news!
    better diagnostic weather this week :cool:
    daisy555 likes this.
  2. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    Service manager confirmed left wheel bearing. $725 for one $1325 for two. Ugh!
    #22 daisy555, Mar 14, 2022
  3. ChapmanF
    18,961
    If only one has failed, I would replace just the one.
    In my Gen 1, which I kept until 23x,000 miles, I eventually had to replace two wheel bearings, one rear and one front, but they failed three years and 50,000 miles apart, and the other two never gave any trouble.
    There's no law of nature saying one wheel bearing's failure means another is right around the corner. A lot could happen in 3 years or 50,000 miles. Maybe you'd have traded the car by then.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    A wheel bearing can be done by any auto mechanic. On a gen 2, no one does the bearing, but instead it's easier/more convenient to just replace the entire hub assembly.
  5. daisy555
    1,729
    716
    CT
    Thank you! If all goes well with funding I’m on a waiting list for a new Prius but I was told best case would be May. They said “front wheel bearings are noisy but left seems to be louder.” Not the best timing but never is with cars.
  6. daisy555
    1,729
    716
    CT
    Thank you! I’m waiting on estimate from a reputable mechanic. If I’m not keeping this car long term, I guess I don’t need the Timken? Unless I decide to sell privately rather than trading in. It’s been well taken care of and I will miss it. I’ve loved this car! : (
    City Tire quoted $1000 for Timken and $650 for Durango for replacing both front.
    Dealer said $2000-3000 as trade in knowing about wheel bearing.
    #26 daisy555, Mar 14, 2022
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,013
    6,902
    Texas Hill Country
    Any shop can do a wheel bearing. The front is a little more time and you don't want a cheap hub bearing because they don't last. However, a Timken hub is quality and fits either side. If the mechanic tears down the left and does not hear the failed bearing, he moves to the right. Probably a $350 job total.
    Timken HA590064 Wheel Bearing and Hub Assembly | CarPartsDiscount.com
    #27 rjparker, Mar 14, 2022
  8. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    Two points
    There are likely many mechanics in CT that can do the wheel bearings if they really need it done immediately. The dealer should be the last option on a car you’re selling.
    I would advise against trading in the Prius for the pittance the dealer or any dealer will give you. You can easily sell it for more yourself on CL of Cargurus. Fixing a wheel bearing is trivial. Take a look at what others are selling similar Prius’s for. Probably easily worth $5,000 or more in this market. Likely $8,000. A quick $5k in your pocket.
  9. Another
    1,819
    520
    Naples, Florida
    All dealers rip people off on trade ins. Oh well, that’s just what they do. No animosity towards them, they have to pay for their overhead. Also private transactions typically benefit the buyer in most states because sales tax on old cars in very low of zero. What that means is that your car is more attractive to a buyer if you sell it rather than the dealer.
  10. daisy555
    1,729
    716
    CT
    Thanks. That’s what I was thinking. Back in 2015 when I bought this 2009 I sold my Pontiac vibe for $2500 and it had front end damage, bald tires and occasional tripping of transmission code although no transmission issue could be found. Obviously I was upfront about all of it.
    If I’m going to sell it myself, I guess it only makes sense to get Timken bearings.
  11. bisco
    52,789
    i can't understand how a bearing relates to your description in the first post
  12. Another
    1,819
    520
    Naples, Florida
    Me neither.
    Like I said, if you’re selling the car don’t put money into it needlessly.
    And above all don’t trade it in. Sell it.
  13. daisy555
    1,729
    716
    CT
    I’m still a bit concerned about that too. It’s like a low grade growl sound but sort of like revving when I’m slowing down.
    There are no other hybrid mechanics in my area. Maybe I could drive to a basic mechanic and have them take a listen. Maybe I’m just bad at describing sounds.
  14. Another
    1,819
    520
    Naples, Florida
  15. Another
    1,819
    520
    Naples, Florida
  16. daisy555
    1,729
    716
    CT
    I don’t want to put another dime into it but I need to drive it until I can replace it. I’m single with no family around. I just canceled a doc appt because I didn’t feel safe going on highway.
  17. bisco
    52,789
    growling can be a bearing, but it is the rest of your description that is confusing. i'll quote it.
  18. bisco
    52,789
    okay, reading it again, i might be misinterpreting. 'not in ev mode' might be because you're moving too slowly?
    'foot off the gas' might mean you hear the bearing because the engine is idling.
  19. bisco
    52,789
    also, bearings don't always fail catastrophically, you might be able to drive it until you get a new car.
    the noise will likely get much louder before failure.
  20. rjparker
    11,013
    6,902
    Texas Hill Country
    A wheel bearing sound is usually quiet when cold until a mile or two makes it more obvious. Generally they are loudest at 35-50 mph. At higher speeds road and engine noise drowns them out. Sometimes they get a little louder on a curve in that 35-50 mph range. They are difficult to hear jacked up because of the brake friction and drive axle on the fronts. Once the brakes are removed, an easy job, the wheel bearing is easy to hear. After you hear one and have had it fixed its easy to diagnose in the car. Any mechanic past the oil change stage easily recognizes the problem.
    Given the car is worth $5k-$6k more AND you have to wait for a replacement, go to a local general mechanic who has his own shop and get one hub replaced. No hybrid expertise required.
