2009 Prius - Revving sound??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by daisy555, Mar 12, 2022.
  1. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    : ) Thank you!
  2. ChapmanF
    18,964
    In terms of the actual work required, it's pretty much exactly 2✕ the work to do two.
    Now that doesn't necessarily mean a mechanic who would like to sell you more work won't offer some discount (maybe charge for 1.8✕ the work instead of 2✕) in order to persuade you. That can be a savvy sales move whether or not there's really less work involved.
    And if you get offered that kind of a discount to do two bearings, and you want to do two bearings, then by all means accept the discount. :)
    It's hard to generalize how long the things last. It's generally a long long long long time. But that can be affected by a lot of different things ... how many hard pothole hits each corner of the car has taken ... if there was a dragging brake for a while in one corner that heated the hub and cooked the grease ... etc., etc.
    The bearing manufacturer can probably quote you a "mean time before failure", but it's one of those situations where the variance is so high (the bell curve around the mean is so broad and so flat) that, combined with the fact there's no real work saved doing more than one together, it's pretty reasonable to just let each one wear out whenever it's going to, and replace it then.
    daisy555 likes this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,020
    6,912
    Texas Hill Country
    Certainly the dealer offering an oem bearing installed with warranty for $575 is an equivalent or better deal overall than the independent at $1048 divided by two. The dealer has effectively matched the independent price. He still has a lot of margin left at $575.
    As long as you are really going to replace the car as soon as the new one comes in. You will certainly make several thousand more on the trade. If you might fall in love again with the current car because it drives so good, I might go with the independent. You are likely to need him in the future when the real bills start coming in.
    #63 rjparker, Mar 16, 2022
  4. daisy555
    1,729
    716
    CT
    Thanks! Good point. I do need a good independent mechanic. I almost used this mechanic when I had my old Saab but their garage was such a mess that I got turned off. Ended up finding a Saab specialist who had a garage at his house. Friendly, honest and organized. : )
  5. daisy555
    1,729
    716
    CT
    Thanks! The service manager explained this exact thing today. They are going to replace the left one first and might not need to replace the right. He promised me if the second one fails later on he’ll still give me the discount. Getting it done tomorrow!
    dolj and bisco like this.
  6. daisy555
    1,729
    716
    CT
    All done! They only did the left because the right checked out ok. He changed price from $575 to $550…even better. Certainly not the deal TMR-WAP offered. : ) Now fingers crossed the right one lasts for a while.
    Thanks everyone for your patience and the time you spent helping me!
    Maria
  7. Mendel Leisk
    42,286
    I've noticed, after battery disconnect on my 3rd gen, the next few start ups (3 or 4) there'll be an odd rev-up, for just a few seconds, just after start-up. I've attributed by experience at least, to the car's computers needing to do some recalibration.
  8. daisy555
    1,729
    716
    CT
    Good to know. Did you see my update? Left hub and bearing assembly replaced today. Only needed the one. Yay!
    Thanks for your help!
