2009 Prius Techstream Data Log Request | Running at its best?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by black_jmyntrn, Dec 19, 2024.
  1. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    410
    2013 Prius Plug-in
    I’m trying to diagnose an issue with my Prius that has me stumped. Despite having no check engine light (CEL) and all sensors showing values within spec, my fuel economy is abysmal—Hybrid Assistant rarely shows above 10 MPG, and my last tank came out to a dismal 11.4 MPG (manual calculation).
    I suspect something is off but haven’t been able to pinpoint it. My thought is to compare a Techstream export from a properly functioning Prius (getting 40+ MPG) to my own data. Ideally, seeing the full range of recorded values from a healthy car will help me identify any discrepancies and give me a clearer idea of what to focus on next.
    For example, I’m considering whether it could be something like the O2 sensor or the aftermarket catalytic converter with the elbow that I recently installed. Having a reference point would really help narrow things down.
    If anyone could share their Techstream export or data from a vehicle that’s running efficiently, it would be greatly appreciated. If my approach works, I might even be able to set up a system where members can upload their data files, and it would automatically analyze and flag potential areas of concern based on deviations from baseline data.
    Thanks in advance for any help or suggestions!
  2. Tombukt2
    Tombukt2 Senior Member
    13,855
    2,516
    Durham NC
    11 mpg and nothing obviously wrong. Like a hole in gas tank isn't this a unit that's five feet in air w tractor tires?? 11 mpg would sound about correct ..no? Or is this a bone stock unlifted daily driver ? You're the guy w metal lift spacers and underpinnings for four wheeling. Like monster trucks look?
    black_jmyntrn likes this.
  3. Brian1954
    Brian1954 Senior Member
    2,674
    1,071
    South Central PA, USA
    Look at the long-term fuel trim. What are you seeing for your car?
    #3 Brian1954, Dec 19, 2024
    mr_guy_mann likes this.
  4. Tombukt2
    13,855
    2,516
    Durham NC
    I lost 5 mi to the gallon lifting the car 40 mm and going to 205 65 15 tires that plummeted my gas mileage to below 37 for the most part Just those two changes nothing else has changed in the life of the car the amount of driving is the same the mileage and all of that everything The only thing that changed was the lift and the tire size and it showed up immediately on the MFD like the minute I put the tires on the road and push the power button it never came above 37.9 miles an hour and this has been months now and I know that the minute I put the 195 65 15's back on the car the mileage will go up two or three miles to the gallon just from that alone and then if I put the front end back down where it's supposed to be it'll probably go back up to the 44 45 that an '07 generation 2 with 340,000 mi on it should be doing I thought Jimmy's car was you know running tractor size tires in other words tires as tall as I am and lifted feet or something similar his car looks like all the other seriously lifted Prius on the given pages I've seen them on nothing like mine in other words so I would expect that might plummet you into the 15s at least he's claiming 11 not that far off I mean when you're inviting another vehicle and that much air to drive right under your vehicle I would think that the MPGs are going to take a serious hit but that's just me apparently.
  5. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
  6. Tombukt2
    13,855
    2,516
    Durham NC
    Well I can't easily blow that up but that looks basically like my business and yes you should be getting more than 20 mi to the gallon absolutely that looks like about a 40 mm lift and somewhere around 205 65 15 tires or close to that same outer diameter around 26 in total OD That's what my car has I don't even need to post a picture It looks just like yours basically and like I say I'm getting 37 and it doesn't budge from that when I fill it up it starts off at 41 and plummets to 37 within 35 mi on the MFD and stays there permanently unlike with the regular tire size and the front end where it's supposed to be down on the ground the same card gets 43 to 45 being driven sometimes unreasonably so there should be something jumping out at you at 11 miles to the gallon even 20 I would think just looking at her another Prius right up the street from you freeze frame data something should pop I don't know what but something I don't know if your brakes are dragging or what you've got going on but 11 mi to the gallon on a 1NZ engine I mean even if it was blown and running racing fuel that shouldn't be.
  7. Tombukt2
    13,855
    2,516
    Durham NC
    So then apparently your car is not serious lifted You're not with the Prius off-road crew so on and so forth apparently at least this car isn't The pictures of the Prius I have in the off-road club have tires on them almost as tall as I am and I'm not a midget they are really lifted like ridiculously so
  8. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
  9. Tombukt2
    13,855
    2,516
    Durham NC
    So if you put the car in maintenance mode or put the heat on when the car is cold so the car won't stop running you should be able to stand behind this car and your eyes water or your sneaker soles start to melt off your shoes something I mean you ought to be burning up some fuel 5 mi to the gallon consumption rate I mean that ought to be like lighten up the tailpipe almost I would think or something that ought to stink like crazy I'd be looking at my MAF sensor and all that stuff something I'm sure you've cleaned it and done whatever but all that stuff needs another going over having to look at something maybe something shorted I can't imagine
  10. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
    just MAF huh.. well okay. I got some brake cleaner and will go to town on the MAF here now.
    so now... could... O2 sensor? Let's say the one installed is from a Gen 3... just wired to the right wire locations?
    you see.. this is why I was asking for one from someone's car running properly.. I feel like there is something in the data I could identify and some how tie back to a sensor.
  11. Tombukt2
    13,855
    2,516
    Durham NC
    Well I got 4 cars all getting 40 ish being driven .by adults the only low mileage Prius I have is one looking like yours 205 65 15 40 mm lift . None stock proper hybrid engine atkinson . . Aren't you running a Yaris motor in yours non Atkinson and so on or did that not make it to fruition I can probably send you when I figure out how to print them the freeze frame data sets I don't think there's any difference from the two that do about correct mileage in my lifted has stated above I'm going to look today but I'm don't really think so but I'm sure there must be because the numbers are different so some things different the width of the contact patch in the amount of air getting up under the front end lifting the car up or something that's why cars don't do that generally I would have to think something along those lines people have spent 70 years getting those cars down on the ground and their contact patches with the road dialed in to vehicles weight and all these other factors and here I come along and just slap some crap on the car and wonder why I'm 8 9 mi to the gallon off I don't think I'm really wondering.
  12. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
    @Tombukt2
    thanks for your detailed reply and insights into your experience with modifications! Let me address your questions and provide some additional context:
    1. Modifications: My Prius only has a lift kit and subframe spacers. It’s not heavily modified beyond that—no oversized tires or extreme adjustments that would significantly increase drag or weight.
    2. Driving Habits: There haven’t been any changes to my driving habits. My routes and driving style remain consistent with what one would expect for a Prius.
    3. Techstream Data: I’ve provided long-term fuel trim (LTFT) and other diagnostic data in this thread. If you notice anything off or have suggestions based on those logs, I’d appreciate your input.
    4. Baseline Reference: Unfortunately, I don’t have a baseline for comparison since I was given this car in a non-operational state. It initially needed a new HV battery, but I later discovered it also required a new gas tank and engine. I ended up installing a JDM motor, so my starting point wasn’t with a stock, functional vehicle.
    Additionally, I’m using an O2 sensor from a Generation 3 Prius, which may be worth considering in terms of compatibility and performance.
    Let me know if there’s anything else you’d recommend I check or adjust based on this information. Appreciate your help!
    Cleaned the MAF and no change.
  13. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
    well.. I remembered I had to install a Gen 3 Oxygen sensor and modify the connector to work... figures since Advanced Auto is having 80% off I might as well install a nice Denzo. Well,no luck... I will say tho, it looks like when you use the right Oxygen sensor you don't need the 90-degree elbow from the sensor to the aftermarket cat.
    could aftermarket cat cause bad mpg? asking as its not the one everyone says to get, I bought this before that recommended one became available. Also noticed after the last time off the pavement and not lifted that I bottomed out hard a few times... now that Chia Cat sounds like something was knocked loose on the inside, it rattles now... this is the latest fuel trim. Screenshot_20241220-194318.png Screenshot_20241220-194156.png Screenshot_20241220-194217.png Screenshot_20241220-194302.png
  14. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
    well.. that nice sale at advanced auto parts made me go buy new spark plugs and refurbished injectors... fuel trim changed once again..
    Screenshot_20241221-123910.png Screenshot_20241221-123923.png Screenshot_20241221-123852.png
  15. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
    looks like cleaning the PCV Valve makes for slight lean condition... gonna check for vacuum leaks or exhaust leaks later today
  16. Hayslayer
    Hayslayer Active Member
    534
    325
    Since it's important to learn something new every day, and my level of "confidence" is in question I thought maybe I could help narrow things just a smidgen for now.
    On a Gen 2, which your photo appears to be (please correct me if I'm wrong): The downstream O2 sensor (B1S2) doesn't do ANYTHING for air fuel ratios. It's merely used to check the condition and efficiency of the catalytic converter. It provides zero information used for adjusting ratios.
    The upstream air/fuel ratio sensor (B1S1), mounted in the exhaust manifold, is a wide band sensor that provides the input for the ecm tuning the AF ratio.
    My tidbit for today.
  17. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    That would be at the top of my list. If the catalyst bed is broken up then the chunks can restrict exhaust flow. The engine has to work much harder to push (pump) exhaust out.
    Quick test with a scantool hooked up. Drive at around 50mph. Now accelerate full throttle to 75. What's the highest MAF and RPM readings?
    On my 2006 I had about 56 grams per second at 5000RPM at 75mph.
  18. mr_guy_mann
    4,113
    2,011
    NJ-USA
    That's correct for a Gen2 Prius, and for MANY other cars as well.
    BUT, there is something known as "downstream fuel trim" which does use the after- cat S2 oxygen sensor to adjust fuel mixture under certain conditions. Toyota began using it on some California emissions cars in the late 80's. Now it is fairly common.
  19. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
    Well, I finally figured out what the issue was with this motor — and after blowing up two engines, I can say with confidence: the culprit was a JDM Corolla 1NZ engine, not the proper JDM Yaris/Echo/Scion version that matches the Gen 2 Prius.
    Here’s what I’ve learned:
    JDM engines don’t come with VINs, so there’s no reliable way to confirm what vehicle they were pulled from just by looking at the block — unless you know what to look for. For a true Gen 2 Prius-compatible JDM engine, you want the one that has the two lower mount holes that go all the way through the block. If someone tells you “Oh, just drill out those holes on this JDM engine and it’ll work,” that’s a red flag — because it might be a Corolla 1NZ, and it will bolt in but won’t run right.
    That’s exactly what happened in my case. Both motors I got were sold as Prius-compatible, and both ended up having timing errors. After swapping in Prius sensors, rechecking all my wiring, and even rebuilding parts of the system, the car still wouldn’t behave properly. Only after digging deep into the timing signal differences — crank and cam tooth spacing, missing teeth positions, sensor response patterns — did it become clear that the Corolla’s crank and cam trigger wheels simply don’t match what the Prius ECU expects.
    If you’re using a Gen 2 Prius ECU, it has very specific timing signal requirements. The Corolla’s gears will cause sync issues, misfires, or complete no-start conditions. And this all started to click for me after realizing both of my blown motors died at the exact same spot on the freeway — going up the hill on the 10 East toward Forest Lawn.
    This week I’ll either be:
    • Installing a proper JDM Prius engine that matches all mounting and timing specs, or
    • Rebuilding my original seized motor using the Corolla crank and cam for strength, but keeping all Prius timing gears and sensors to keep ECU compatibility.
    Lesson learned: not all 1NZs are created equal, and if you’re putting in the work to swap one in, make sure you’re starting with the right foundation. Don’t let someone hand you a Corolla 1NZ and tell you it’s “close enough” — it’s not.
    So now.. i wonder what data from the car could've alerted me to this?
  20. Tombukt2
    13,855
    2,516
    Durham NC
    I would think you just be able to swap over the crank gears the camshafts and what you needed because thesignsls coming from in cars ECU"s so engine phasers and cams etc should drop in to replace the wrong stuff so crank driver gear can gears and all that would slide on any NZ engine you're prepping for this duty cycle. Then it will all speak to each other.lotts this went on early days swapping 3sgte Beams engines in to various cars in US market . Very popular longtime ago. Had to be careful all gears correct tooth counts etc. No room for errors or destruction can be eminent.
