2009 prius turns on but no start. starting or ready problem
Discussion in 'Gen 2 Prius Main Forum' started by rzk, May 14, 2019.
  1. rzk
    rzk Junior Member
    49
    washington
    2009 Prius everything turns on, brake light working when i step on the brake pedal. fob remote open and close all doors and trunk. i put in a new aux battery. i bought the battery from Toyota dealership.
    there is a triangle light with exclamation
    when i turn on the car i get a red or amber light on the push bottom.
    please see attach pictures of the display
    it will go into neutral but not drive or reverse. i can hear all the clicks/sounds from the trunk and in the hood and when i turn on the car and i can also hear the noise r sound from the hood when i open the driver door.
    please please help me fix the car.
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Pictures never help. Get a Toyota capable reader, read the codes and get back to us. No one will be able to help you from those pictures.
    52,819
    welcome!
    tech stream if you are the future mech
  4. rzk
    rzk Junior Member
    49
    washington
    ok thank you. i will get an obd2 to retrieve codes and i will post the codes
    Skibob and bisco like this.
  5. bisco
    52,819
    make sure it is prius aware
    Skibob likes this.
  6. rzk
    rzk Junior Member
    49
    washington
    how do i go about to do that or get the prius aware on obdII. the 12 volt is good. is it a brand new battery from toyota dealership
    #6 rzk, May 15, 2019
  7. Skibob
    2,912
    1,505
    Northern California
    There is no program called Prius aware. He just meant get a code reader that can read Toyota specific codes, not just the generic emissions codes that cheap code readers read.
    If you search around this site you will find what people are using
  8. rzk
    rzk Junior Member
    49
    washington
    i checked for codes today. i only get one code.
    the code is . P0AFA
  9. bisco
    52,819
    you need tech stream if you are going to diy. torque, elm and a few others all work about 90%, but you may need the 10%.
    tech stream is available on amazon. you need a compatible laptop to run it. the others are phone apps.
    Skibob likes this.
  10. bisco
    52,819
    for code info and troubleshooting, see the repair manual at tech info.toyota.com, or search online for a free copy.
  11. bisco
    52,819
    i would start with a test of the 12v. they can be defective, or require a charge before installation.
    once you have confirmed its goodness, it looks like P0AFA is related to a hybrid battery issue.
  12. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    rzk,
    Let's back up to get a bit of history to figure out how we got to this point?
    - Have you had this car for a while and it just started having this problem?
    - Did it first have this problem while driving? Or did you simply come out one morning and it had this code?
    - Have you done any work with the hybrid battery before? Opening it up, removing it, etc.
    jerrymildred likes this.
  13. rzk
    rzk Junior Member
    49
    washington
    hi? battery aux is charge. voltage is above 13
    i inherited the car. it has been driven for about two months. no start. i replaced the aux battery
    did it first have this problem while driving? i don't know. i got this car in this condition. not starting i don't have any more info about the car
    no work to hybrid battery. i only changed the aux battery.
  14. bisco
    52,819
    above 13 is unlikely. do you know how to do a voltage test?
  15. rzk
    rzk Junior Member
    49
    washington
    i attached a trickle charger from the hood terminal. the trickle charger says aux battery fully charged volt is 13.
  16. bisco
    52,819
    yeah, they aren't accurate. there's a surface charge giving an incorrect reading. you need to check it in the morning after
  17. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    So you wrote
    "It has been driven for about two months"
    Did you mean it has NOT been driven in two months?
    If that is the case then the hybrid battery may be too low to start the car. That will be a big headache for you, as you will need some special equipment to get it up to the correct voltage.
    You definitely need a few tools so you can share some data, like Hy rid battery State of Charge, high voltage battery block voltage, etc.
    If you don't have diagnostic tools, then you can go old school and use a voltmeter. Bit that will involve quite a bit of dismantling the car.
  18. Skibob
    2,912
    1,505
    Northern California
    I thought the same thing. He say he has never driven it in another post. He needs a mini VCI and a copy of Techstream. I don’t know what he’s pulling codes from but Techstream would give him all the codes and he could check the HV battery too. He says he bought a new 12v so that’s probably ok
  19. rzk
    rzk Junior Member
    49
    washington
    thank ya all for helping. yes the car has not move or stared in the last two months. i did some work in the trunk today. i started to dismantle the battery area. when i took out the hybrid battery computer the orange plug in, the pins inside has numbers. i see some corrosion and burnt areas between number 9 and 7. i can see one spot of black on the harness that plug into the computer. i cleaned the hardness. computer number is 89890-47092
  20. JC91006
    16,936
    8,647
    Why did you start disassembling the hybrid battery? Maybe you messed with the Orange interlock switch on the battery and didn't lock it back into place?
    Did you remove that when you installed the 12v battery? Anytime before the 12v battery change?
