2009 prius turns on but no start. starting or ready problem
Discussion in 'Gen 2 Prius Main Forum' started by rzk, May 14, 2019.
  1. rzk
    rzk Junior Member
    49
    washington
    this is the first time of touch anything pertaining the hybrid battery system. i touched it because i want to look at the connection between the battery and hybrid battery computer
  2. rzk
    rzk Junior Member
    49
    washington
    are the burnt or corrosion pins in the computer indicate anything
  3. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Post pictures of harness burn/corrosion. Probably bad HV battery ECU or battery. But pictures would be a plus
  4. JC91006
    16,939
    8,647
    Yes that has been reported by some members. Might have to replace both items.
    There may be some extra harnesses costing around, just have to post a WTB post
  5. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Corrosion at the computer connector can mean corrosion internal to the computer as well.
    Remove it an open it up. Corrosion can continue on down the pins and onto the computer board.
    Replacing it may be the best option for safety if corrosion is present.
    This also means that corrosion has traveled from the module posts to down the sensing wires. So the wires themselves can be suspect.
    Checking the crimp connectors at the ring terminals would be in order.
    Don't forget the one hidden under the negative lead at the far end of the battery pack.
    Speaking of the negative lead, it too can contain a disgusting amount of corrosion hidden inside the black sheathing.
    Most people just ignore this corrosion because they do not want to spend any money to get proper replacement parts.
    Instead they try all sorts of home remedies of scrubbing, soaking, coating what are failing components.
    But they are happy to have saved money.
    jerrymildred and SFO like this.
  6. rzk
    rzk Junior Member
    49
    washington
    i will take pics and upload
  7. rzk
    rzk Junior Member
    49
    washington
    i checked the battery today. i found about 11 cells with volt lower than 2
  8. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    Lower than 2 (two)?
    Than is horrible.
    What were the rest?
    You will need to get all of them much higher. Nominal voltage is 7.2
    You can do this one module at a time with a small low voltage charger. This can take weeks.
    Or do the entire pack at once with a high voltage charger. This will take a day.
    Raytheeagle likes this.
  9. rzk
    rzk Junior Member
    49
    washington
    Ericbecky please tell me what charger to use or to buy. name and model of the charger to use. how to hook up the charger to the battery. i have a trickle charger. it is called viking 63350 4amp .
    4 Amp Fully Automatic Microprocessor Controlled Battery Charger/Maintainer
    i will like to charge the battery and see if there is life. the other cells are above 7.2 volts.
    thank you
  10. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    If all you have is a 12v charger, then that is what you will need to use.
    It is not the right tools and not an elegant solution, but you can try.
    4amps is quite a bit higher than optimal.
    You will see that the modules have a positive terminal + and a negative terminal -.
    You charger will have a positive lead +. (red?) and a negative lead - ( black).
    Put your charger on lowest amperage.
    Working with one module at a time.
    Put positive charger lead to positive module terminal.
    Put Negative charger lead to negative module terminal.
    Measure voltage as you charge.
    Stop when it it near the other modules. Within 0.1v or so.
  11. rzk
    rzk Junior Member
    49
    washington
    thank you. is it possible to connect the terminal to the two hybrid connection and charge the whole battery at once
  12. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    You can jump start from another Prius hybrid battery.
    It is very dangerous. You definitely can kill yourself and others if you make a mistake.
    I'd wear high voltage protection.
    It would be safer to buy a high voltage charger or high voltage power supply. Either make one. Buy one. Repurpose one from another piece of equipment. (For instance and electrophoresis machine.)
    Call me during the day and we can discuss.
    608-729-4082
  13. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    I think your giving this guy bad advice. In my opinion he does seem capable of repairing his battery by himself
    Dxta likes this.
  14. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Please, if you don't seem knowledge or capable of doing what you intend doing, pay someone to have the job done for you.
  15. VFerdman
    VFerdman Senior Member
    1,200
    1,221
    Western Massachusetts
    Would a Prolong charger help? They are expensive, but may be worth it in this case.
  16. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    Touching the end of a high voltage wire when it is live can definitely kill you. Dead. Forever.
    @rzk this is your first time working on a high voltage battery. Being very careful is important.
    I do not recommend charging from another Prius. Especially if you have other safer options.
    You asked if it was possible. The correct answer is that it is possible. But I would not consider doing it if I were a novice. Electrocution protection and other personal safety equipment would be required.
    Skibob likes this.
  17. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Have the car towed to a dealer that has a grid charger is a safe option. It will cost you, but it can’t kill you. It might kill your wallet, but not you.
  18. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    Many dealers do not have a charger handy.
    They may need to request it from a central location.
    Plus I don't they would do anything with charging the pack.
    The pack sounds like it has some serious issues.
    - battery modes less than 7v
    - corrosion on the computer
    These are major red flags.
    @rzk if you call.me I can walk you through some ideas and maybe better help you troubleshoot some things. 609-729-4082
  19. Chrisruiz0310
    Chrisruiz0310 New Member
    Lynwood CA
    Need help
    With a 2010 Toyota Prius.
    Code reads p3190
  20. Chrisruiz0310
    Lynwood CA
