2009 prius turns on but no start. starting or ready problem
Discussion in 'Gen 2 Prius Main Forum' started by rzk, May 14, 2019.
  1. bisco
    51,944
    start by adding at least 3 gallons of gas.
    what are you reading the codes with?
    SFO and Raytheeagle like this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Some questions:
    • How much gas is in the tank?
    • How many miles on your Prius?
    • Cleaned the MAF sensor?
    • Cleaned the throttle body?
    • Any recent incidents?
    Good luck and keep us posted (y).
    SFO likes this.
  3. Chrisruiz0310
    Chrisruiz0310 New Member
    Lynwood CA
    Gas 1/4 about 60 miles on it
    Miles 97k
    Not cleaned yet MAF
    Not cleaned throttle body yet
    When it turn it on. It does this rattling engine sound and turn off.
    Raytheeagle likes this.
  4. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    I’d take @bisco ’s advice and add fuel;).
    The rattling you are hearing could be due to lack of fuel.
    Keep in mind that the more times you attempt to start your Prius, the lower the traction battery gets:cool:.
    How low was the reading on the traction battery? I see you are using an OBD2 reader that might not be able to delve further into the codes. Your battery might already be too low causing the P0A80:(.
  5. Chrisruiz0310
    Lynwood CA
    Traction battery was 1 bar. And it reads. Please put car on parking low battery. Traction.
