2009 Prius won’t start (You guys have probably seen this 100 times).
Discussion in 'Gen 2 Prius Main Forum' started by 550/440, May 11, 2019.
  1. 550/440
    550/440 New Member
    Mesa
    2009 Toyota Prius, would not start. Took it to the dealership and they diagnosed it as having a bad hybrid battery. Had it towed home since I figure I can do that one myself and installed a new Dorman battery. Still will not start, everything lights up including almost every single warning light. Makes a click in the back when I Attempt to start it. Will go into neutral but will not go into drive or reverse. Any help? I’m stumped.
  2. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Welcome to PriusChat!!
    Wish you would've found Steve at PHOENIX HYBRID BATTERIES - the very best option in that area.
    Or you could've had one shipped (free shipping) from : Pricing | Hometown Hybrids
    Not sure if you have a return policy on that Dorman, or if you've already turned in the old HV battery for the core charge.
    Have you checked the orange safety plug for proper installation?
    Most likely the vehicle is throwing some DTCs (codes) and you have lights on the dash, please read the OBD2 codes and post them here.
    Raytheeagle, Skibob and fotomoto like this.
  3. tonybluegoat
    tonybluegoat Junior Member
    17
    east texas
    Push the big red disconnect DOWN. I've had this same issue. Replaced my own battery, put the big disconnect back in and got everything but no start and a red triangle. The big disconnect switch has a small connector on the bottom that tells the computer it is in place. After you close it you have to push it DOWN about half an inch for that indicator to connect. Hope this helps.
    51,113
    see above posts
  5. JC91006
    16,672
    8,518
    It's very uncommon for a car not to start from a hybrid battery failure. There is usually plenty of juice in a failed battery to start the car.
    A more common issue would be a shorted inverter pump. But a dealer would know by checking the codes. Did you pay then to diagnose the car or did someone guess at it?
