2009 Red master warning , VSC and yellow brake system lights on. Only get intermittent acceleration.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by nicov, Nov 5, 2019.
  1. nicov
    nicov New Member
    Australia
    i-Tech
    My Prius automatic 2009, odo about 175,000 kms has recently suffered from the following and I’d really appreciate some tips on most likely causes from you dudes and dudettes….
    • Red master warning light on all the time
    • After driving beyond about 20kms, VSC and yellow brake system light come on and then I only get intermittent power when accelerating.
    • Also have the following trouble codes but can’t access further sub-codes with setup I have….
    ABS/VSC/TRC C1310 HV SYSTEM MALFUNCTION current but no history??
    HV BATTERY POA84 HYBRID BATTERY PACK cooling fan 1, control circuit low current and history
    HYBRID CONTROL P3000 BATTERY CONTROL SYSTEM current and history
    I’ve searched the forum a lot but found nothing quite the same.
    Any ideas??
  2. dolj
    dolj Senior Member
    7,529
    3,783
    Wellington, New Zealand
    I'd look at the hybrid battery cooling fan (P0A84–Hybrid Battery Pack Cooling Fan 1 Control Circuit Low). Check it is clean, check the connections and check it is running.
  3. nicov
    nicov New Member
    Australia
    i-Tech
    Thanks dolj!! Just found a video on how to do that so i'll give it a crack. cheers
  4. nicov
    nicov New Member
    Australia
    i-Tech
    Hey there Dolj
    I took the fan out and it had a fair bit of dust gunk in it so it was good to clean that out. when i put it back and cleared the trouble codes, it drove really well with no warning lights for about 20kms but then the same lights returned....bugger!!
    Any other ideas?
  5. bisco
    49,089
    how is the 12v health?
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,111
    5,820
    Columbia, SC
    Clean is great, but useless if the fan isn't running. Make sure the fan is actually running. The plastic duct attached to the bottom of the HV battery has a controller mounted in it. That device is what controls the fan. Sometimes, when people mess with the battery, they unplug this and forget to reconnect it. Your code is saying the fan isn't receiving power. Fuse, relay, harness or controller problem, most likely.
    Troubleshooting Guide....
    dolj likes this.
  7. nicov
    nicov New Member
    Australia
    i-Tech
    Not sure it could be the 12v battery according to AUTOCODES....POA084, the Possible causes as
    Faulty Battery Cooling Blower Assembly
    Battery Cooling Blower Assembly harness is open or shorted
    Battery Cooling Blower Assembly circuit poor electrical connection
    Faculty Integration relay
    Faculty Battery smart unit
    Faculty Power management control ECU
    so I think i'll check on these first.
    By the way, I confirmed yesterday that the fan is blowing so it is strange.
    I wonder if one of the HV battery cells was getting old and heated up too much, perhaps the fan could not keep the temp down low enough or would that trigger a different trouble code/light?
    Thanks for the tips and doco TMR-JWAP but i confirmed the fan is blowing yesterday. Might check the connector for the fan as dirt could cause the signal voltage level to drop and run the fan lower than intended. I'll also check the other things noted in the reply i just posted above. I'll also run through the checks in the doc you posted where they make sense, given that the fan is actually running. by the way, for safety, what do you have to do before taking the hv battery covers off? Also, where did you get the repair manual pdf you posted up? very handy to have these!
    #7 nicov, Nov 10, 2019
  8. nicov
    nicov New Member
    Australia
    i-Tech
    SOLVED!!!
    Finally, got it!!
    In the end, it was one wire of a harness, as per the image of the page from the 2006 Prius Repair Manual.
    The brown wire from the Battery ECU Connector, FCTL1, B11-10 to the Battery Blower relay No. 1 (B14-2) allows the Battery ECU to close the contacts on the relay and hence allow power to flow to the Battery Blower, so clearly, if this wire is not communicating (ie. it had open circuit, infinite resistance), then you'll get the P0A84 Trouble Code. The thing that threw me earlier was that I had thought that I had felt air flowing out of the exhaust duct from the HV batteries near the aux battery (there is a hole in the duct there presumably to cool the aux battery).
    Note that previously I thought I had solved the issue a couple of times after 1. cleaning the HV Battery fan and 2. replacing the Blower Relay (as I had read that it had a closed contact resistance of 6kOhms).
    Anyway, thanks heaps to everyone for helping me out and in particular, sharing the links to get the proper manuals - this is a GREAT forum for tinkerers like me without enough cash to pay to get this stuff done and I reckon this would have cost over $1k to get a mechanic to sus out and fix but I'm only guessing there. I used a Selidori link I found on this chat to get the manuals but can't post the link as the system says I don't have enough posts but you can search it on
    It did cause one chrome pop-up to seemingly begin popping up continually (or maybe it was something else?) but well worth it to get the manuals which were and are vital to solve the problems assuming you have the mini-vci cable and Techstream software to get the trouble codes.
    By the way, does anyone know how can I flag this post as SOLVED?
  9. bisco
    49,089
    congrats, well done!(y)
  10. nicov
    nicov New Member
    Australia
    i-Tech
    Thanks Bisco, very satisfying nut to crack as you'd well know!
