2009 red triangle after sitting in tucson heat.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ken D., May 21, 2023.
  1. Ken D.
    Ken D. Junior Member
    Tucson Az
    I have a 2009 prius. The check engine light has been on for months but It has been running fine. Today after car sitting in the Tucson sun for several hours we came out and started it and put the AC on. The red triangle came on with some other warning lights. This also happened last year around this time when the outside temperature got hot. Any ideas?
  2. JC91006
    16,937
    8,647
    My idea is to get the codes read from Autozone or similar auto parts retailer. That'll point you to the right direction of this failure.
    Best case scenario...well there isn't one.
  3. Bob-W8RH
    Bob-W8RH Junior Member
    Maricopa Arizona
    I'm up here in Maricopa Arizona I would check your cooling fan on the battery. Also one how is your inverter pump I've replaced mine several times.
    Prius Chick and bisco like this.
    52,878
    i'd say it's heat related
  5. ChapmanF
    19,041
    As you have warning lights on the dash, which means there are trouble codes telling you what the car has detected to be off, I will also cast my vote for posting what those trouble codes are.
