2009 Yellow Brake Warning Light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ridge_Prius, Sep 23, 2020.
  1. Ridge_Prius
    Ridge_Prius Junior Member
    New York
    2009 Prius with 120,000 miles. I have a yellow Brake Warning light on. (exclamation point in a circle and parentheses). My brakes are operating normally. Shoes and pads are good. No leaks. Fluid level is correct. Parking brake works fine. All brake lights are operational. I tried the paper clip jumper reset. The tire inflation light is on also ever since I changed from my winter tires, although the pressures are correct. I thought this might be one of the inflation valve sensors. Anyone have a similar situation or know of a solution?
    Longinus876 likes this.
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
  3. Ridge_Prius
    New York
    The connector to the Brake Control Power supply, next to the 12v battery, wasn't clicked in all the way. That fixed it.
    Longinus876 and SFO like this.
  4. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Odd. Wonder how that could've happened?
  5. Longinus876
    Longinus876 Member
    105
    Long Island
    What does that box do anyway?
  6. Longinus876
    Longinus876 Member
    105
    Long Island
    I have the same problem with that light being on.
  7. Longinus876
    Longinus876 Member
    105
    Long Island
    Now is that done?
  8. ChapmanF
    18,985
    It makes sure the brake-by-wire system still has electrical power for a while if there is a failure of the rest of the electrical system.
  9. mr_guy_mann
    mr_guy_mann Senior Member
    4,111
    2,011
    NJ-USA
    What codes do you have in the ABS ecu? (there are many codes that can turn the warning light on- knowing what one you have makes for much less guessing).
