2010 1.8 engine replacement
Discussion in 'Gen 3 Prius Main Forum' started by Ernesto Chavez, Jan 3, 2017.
  1. Ernesto Chavez
    Ernesto Chavez Junior Member
    24
    Any good advice from a
  2. Ernesto Chavez
    24
    ...anone that has done an engine swap. This will be my mechanic's first hybrid engine swap. Any links would be appreciated.
  3. lsun22
    lsun22 Junior Member
    16
    sacramento
    the mechanical components are on the left and the electrical components are on the right side, so they aren't intermingled together. if your mechanic has done any engine swap before, they should be able to take care of it, no problems.
  4. ChapmanF
    19,025
    That's where they are if you're standing in front of the car, facing it. Which is reasonable enough, but don't forget that shop manuals are normally written with left and right meaning when facing the same way the car is, putting the engine on the right, and the hybrid tranny on the left.
    Anyway, in the official procedure (I think still in Gen 3), engine and tranny drop out together, then can be separated in the shop, tranny mounted on new engine, then both reinstalled in the car.
    I think I've seen some DIY reports of successfully separating them in the engine bay so just one or the other can be dropped out, but the space for doing that is tight.
    The shop manuals are at techinfo.toyota.com and as long as the mechanic follows them carefully, I wouldn't expect any trouble.
    -Chap
  5. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Not that I recommend it, but it may be possible to replace the engine with the transaxle still attached.
    See this video of Carolyn at Luscious Garage replacing MG2 on a Gen1. She didn't pull the entire engine/transmission.
  6. JC91006
    16,936
    8,647
    You can easily drop the engine without the transaxle attached. Not so easy dropping the transaxle.
