2010 @120k miles. Misfiring after spark plug replacement and sulfur smell?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by snowglobes97, May 25, 2020.
  1. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Re-read my post #17 & emphasizing the last 4 words on sentence one.
  2. Rathmon
    Rathmon New Member
    Boulder Creek, CA
    I just recently went through this exact same thing. Misfire in cylinder 2 & 4. This misfire in 4 is caused by the EGR cooler being clogged with carbon. Coolant is not flowing through it, just around it, therefore the overheated gasses occasionally makes 4 misfire. Plenty of advice here on how to clean it properly (if you don't want to replace it). The misfire in 2 is caused by a bad head gasket. If you're losing any coolant, or if there's coolant in the oil, then you will need the head redone or even an engine replacement. If not, you can try your luck with a gasket sealant product- Bars Leak Carbon Fiber Head Seal worked for me.
    snowglobes97 likes this.
  3. snowglobes97
    snowglobes97 New Member
    Alrighty then.
    Thank you for posting that! Is there anything else I can do to confirm the bad head gasket? The leak-down test didn't show a leak, but the issue not being directly related to the spark plugs makes more sense accounting for the codes not following any of the plugs. So far, I haven't had any coolant level issues. I'm up for replacing the gasket, but would a sealant be good enough in the long run? Or are you saying a new head gasket + the sealant?
  4. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    o_O
  5. jas8908
    jas8908 Member
    42
    38
    dallas
    I had the knocking sulfur odor when the egr valve was duck open. Have the cleaned the egr valve?
  6. Rathmon
    Rathmon New Member
    Boulder Creek, CA
    The only reason for a misfire in 2 (other than a bad ECU) is a bad head gasket. It isn't bad enough to really affect compression it seems, but it's bad enough to allow for the air/fuel mix to be disrupted it seems. From what I've read here, most people that have experienced a more catastrophic failure of the head gasket (meaning coolant loss into the combustion chambers) have all had cylinder 1 compromised. I can't recall if I mentioned here that I replaced the plugs, coil pack, and injectors as well, with the #2 misfire persistent afterwards.
    Try the gasket sealant first- it's $30-40 cost compared to $1200+ for professional repair. It's about a month in and no troubles for me, and we drive in the mountains daily.
