2010 200K Transmission bearing noise?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by AllenZ, May 29, 2020.
  1. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    Initially my mechanics thought it must be right side wheel bearing issue. When he drive in S curve, noise stringer when turning right. He replaced all of them, they do getting loose a little bit, but noise only reduced a little. Now he think it is trans bearing. What do you think? Any similar cases?
    Thanks!
  2. b100
    b100 Member
    144
    75
    Netherlands
    Change your traany fluid, and drives till something fails
  3. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
  4. Mendel Leisk
    40,540
