2010 2011 Toyota Prius Engine Knocking - Defect
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bounce88, Apr 23, 2012.
  1. bounce88
    bounce88 Junior Member
    New York
    Listen to this. I have having a tough time getting this defect fixed by the dealer. Wished Toyota would just issue a RECALL rather than TSB because the tech would bother listening to the TSB. I have the TSB 204-11 and 10-12 which described the issue I am having. I even recorded the sound see:
    They only replaced the engine mount but the problem is still there! They are not fixing the issue unless I leave it with them for a few days. Problem is I need the car and they refuse to provide me with loaner. Isn't the video enough! Guess not. Hope your dealer will listen and address your concern and fix both the engine mount and intake manifold. Frustrated that I have to bring to the dealer too many times with no resolution/fix.
  2. xpcman
    xpcman Senior Member
    1,302
    292
    California - SF Bay area
    Listen to this and it will make you think to twice to purchase 2010 2011 Toyota Prius.
    I bought a car from the first boat load of 2010's delivered to the US. I have never had this problem in over 30k miles. Think twice - I don't know why?
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,777
    Undisclosed Location
    "They are not fixing the issue unless I leave it with them for a few days."
    Then leave it with them for a few days.
    Yes, it's a bummer they aren't giving you a free rental car, I'd lobby for one. But if you can afford a New Prius IV with Advanced Tech Package...then I assume you can afford a rental car for a few days?
    If you are really unhappy with the dealership? Try a different dealership. But you have to give "somebody" the chance to fix it, with or without a rental car.
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,314
    Wilmington, NC
    I agree with bounce88's post. I have been reading these posts and threads concerning the two TSB's that have to do with the vibration and engine knocking. I have about 45k miles on mine and I am also hoping that enough people will complain to get Toyota to issue a recall and stop this nonsense of having to be able to duplicate this problem before performing the engine knocking TSB. I hope this happens before my car approaches 60k miles and will no longer be covered by the warranty.
    The only two times that this has happened to me has been under two particular combinations that will be very difficult to reproduce. When it does happen it sounds like ball bearings clanking around in your engine which cannot be very good for your engine.
    I also bought mine at the end of the summer 2009 so one of the first ones off of the boat.
  5. bounce88
    New York
    Now why should I put more money in a rental car when the car is new and still under warranty? I don't want to waste any money on this vehicle since it is no fault of mines but manufacturer. Will wait until I am able to leave it for a few days and when the weather gets colder (will happen more often)
  6. adamace1
    adamace1 Senior Member
    1,403
    189
    Charlotte, NC
    Cause Toyota does not provide rental cars and they never said they would. Other brands such as GM will back up their cars with a loaner if it needs to be in the shop over a day. Same reason Toyota does not provide a 100k powertrain warranty.
  7. aneumayr
    aneumayr New Member
    Cincinnati, OH
    That is one of the most disturbing sounds I have heard coming from a newer car. Did the car do it from the start? I have a 2011 with 10k, and have never had that.
    Unfortunately, a recall probably won't happen unless a safety issue arises from the knocking.
  8. spiderman
    spiderman wretched
    7,543
    1,540
    Alaska
    ^ Mine did about 1-2 months after I got it (Sept, Oct) twice. Hasn't done it since. Got the new intake manifold installed last month.
  9. The Electric Me
    9,083
    5,777
    What's your priority? What's your problem?
    Is it the defect with your vehicle, and do you want it fixed? Or is it that the dealership you happen to be using, isn't willing to provide you with a free rental car?
    Many times with a newer car, and at a dealership they WILL offer you a rental car, but not always. As stated, it's NOT part of your new vehicle warranty.
    IMO the priority should be with getting your vehicle fixed.
    If you aren't happy with the attention from your dealership? You can seek out another, describe your problem and ask before hand if they would offer a loaner.
  10. massparanoia
    massparanoia Active Member
    697
    467
    Virginia
    I had a jeep that made the same noise. They had to replace a piston in the engine because the hole that was drilled in it to accept the connecting rod was too big. The con rod would rattle inside the hole when the engine was running causing the knock.
  11. Jesse Melara
    Jesse Melara Junior Member
    39
    Los Angeles
    Having the same issue...just bought my 2010 from a Toyota dealer two days ago...taking it back tomorrow so they can fix it. lets hope that they give me loaner if it needs to stay..if not I am stuck there till I can get a ride back home since it is about 30 miles from my house...fun huh. lol Wish me luck.
  12. car compulsive
    car compulsive Active Member
    741
    273
    Michigan
    For me, the noise only occurs if I start the car, allow the ICE to start, turn the car off before the ICE has warmed up (e.g. move the car a few feet and shut it off), and then start the car a number of hours later. Voila, there's a bag of hammers under the hood.
    If I move the car and turn it off before the ICE starts, I don't get the noise on the next restart. If the ICE starts, I allow the ICE to warm up and turn itself off before turning off the car. Following this routine, I haven't had any startup hammering for many months. I have not had the TSB performed.
  13. Jesse Melara
    39
    Los Angeles
    Well, the TSB was preformed and went back to the dealer yesterday to pick up the car...as I was waiting and could see my car from the place I was standing, as the porter turned the car on, it made the same noise and freaked the hell out of the porter. He then got off and yelled, "Its gonna blow" and ran away...a bit dramatic but true. So they kept the car another day. They called today and said it did it again this morning but seems to only happen on start up from cold. So they changed a few spark plugs, did a pressure test and will try again tomorrow morning...thank goodness they provided me with a rental.
    MsGancho likes this.
  14. vito.a
    vito.a Junior Member
    52
    17
    Tucson, AZ
    I'm sorry for your troubles. Unfortunately, a warranty is a contract between you and Toyota and the dealer is the designated service organization. When a problem cannot be reproduced easily, the techs are just guessing.
    This noise does not sound internal to the engine. It is something knocking against something at the rpm of the engine. Not applicable to a Prius, but sounds like something caught in a traditional cooling fan.
    I would want it repaired immediately and find a way to leave it with them. Unfortunately, it may take more than one repair session.
    Best of luck!
  15. MsGancho
    MsGancho New Member
    Grand Rapids, MI
    Our car has about 75,000 miles and it just started this problem this weekend. It's in the shop right now. At breakfast this morning our three-year-old heard a motor cycle start up outside and said, "Right, that's a Prius?" I am the first in my family to buy a Toyota. Come on Toyota, don't prove me wrong. Issue a recall.
  16. Jon Hagen
    Jon Hagen Active Member
    336
    134
    North Dakota
    My experience exactly with my 2010 (spring 2009), no problem unless I turn the engine off without a full warm up.
    Also, I find another trick that works in our far northern climate, is the engine vibrates when first started on well below O F temps when the engine is very cold and stiff.. Start the engine and immediately shift to neutral to stop battery charging load on the engine. The cold engine will run faster and smoother with no charging load.. After the engine warms enough to run smooth(15-30 seconds), shift to drive to restart the battery charge / battery warm up cycle.
    #16 Jon Hagen, Jul 30, 2014
  17. kbeck
    kbeck Active Member
    420
    274
    Metuchen, NJ
    Word is that the problem has to do with condensation inside the intake manifold; later versions have a changed shape. It apparently took quite a while for Toyota to finally nail the problem; there's at least one TSB on how to handle it.
    KBeck
  18. Angel209
    Angel209 New Member
    Stockton
    Which intaaake manifold did u get
  19. Angel209
    Angel209 New Member
    Stockton
    What did they say fixed it
  20. spiderman
    spiderman wretched
    7,543
    1,540
    Alaska
    ? model #?
Loading...
