2010-2014 Prius recall impulse propulsion system excessive voltage
Discussion in 'Gen 3 Prius Technical Discussion' started by GreenTea&SaltWater, Jun 2, 2021.
  1. GreenTea&SaltWater
    199
    58
    Los angeles
    I’ve found out there is a recall for this. Image attached. My hybrid battery stopped working again car completely dead but it didn’t stall out while driving. The gas engine was still working. What’s the possibility this recall is the cause of this?
  2. ChapmanF
    18,961
    I'm not seeing the image. Do the warp engines work?
  3. GreenTea&SaltWater
    199
    58
    Los angeles
    52,789
  5. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Assuming you're using winblows, try using "control-c" to copy the image, then "control-v" to paste the image within the reply box.
    You could also use the mouse/trackpad to 'right click', and then do the same as above.
  6. GreenTea&SaltWater
    199
    58
    Los angeles
    I’m on my phone don’t have access to PC atm
