2010-2015 - Replacing hatch lift supports
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kc410, Mar 8, 2024.
  1. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    One of the gas springs failed recently on the 2010.
    I replaced both with StrongArm 7088 "gas charged lift support" from Rockauto.
    The StrongArm 7088 are _exactly_ the same (extended) length as the OEM 2010 supports.
    The hatch is almost perfectly balanced when opening & requires very little effort to nudge it up after that.
    Closing is fairly easy. The 2010 feels the same as the 2015 with its OEM lift supports
    I was quite confused when researching replacements.
    A few things I learned along the way:
    1) Some places show different part numbers for 2010-2011 vs 2012-2015 vehicles.
    I compared my 2010 & 2015 "lift supports" & both have the same Toyota p/n (68950-0W540, right side)
    So the "lift supports" are the same accross the years 2010-2015.
    2) For some reason Toyota has different p/n for L & R sides.
    All the replacement "lift supports" fit either side, so only one p/n needed.
    3) Rockauto shows 8 items for "lift support".
    None of them is the StrongArm 7088...
    but...
    When I searched rockauto for "StrongArm 7088" they did carry that item:
    More Information for STRONGARM 7088
    That page has: "OEM / Interchange Numbers: 689500W542, 689600W532"
    These are the Toyota p/n for their "lift supports"
    That is what I ordered & they easily "pop" onto the ball ends.
    I noted each end of the new "lift supports" included a tiny blob of lubricant in each recess, a nice touch.
    amarino and Mendel Leisk like this.
  2. Mendel Leisk
    42,239
    Is “one” order a single one, or a pair? I’m guessing you need to set order quantity to “2”, but not sure.
  3. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    You are correct - The StrongArm 7088 are ordered separately so two units are needed.
    @ ~$10 ea, with shipping & tax I think it was $33 for both from Rockauto.
  4. Mendel Leisk
    42,239
    Order placed, worked out to $35.73 USD for me. Thanks for the info; our struts went "off" just a few years in, still functional, but always in need of a boost, and they've been getting noiser/stiffer of late. Will give these a go. :)
    kc410 likes this.
  5. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    Great!
    Just noticed something strange @ Rockauto...
    When I checked earlier this morning, they had 2 "in stock" for $10.02 ea. (what I paid).
    When I look now, the price is $12.62 & they do not show how many in stock...
    although when I started to order 2 more, the web site accepted so they have a stock @ the "new" price.
    Either way its still a great deal when needed :)
  6. Mendel Leisk
    42,239
    Should have clarified, that was all-in price I posted. Here’s the break-down:
    kc410 likes this.
  7. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    Appears you got the last two @ the USD $10.02 price (CAD $13.55)
