2010-2015 Toyota Prius Engine and Inverter Coolant drain and refill video inside
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NutzAboutBolts, Feb 9, 2016.
  1. melvinpriusv
    melvinpriusv New Member
    2013 Prius v wagon
    Thanks for the videos. Well explained. Do you know the part numbers for the drain plug for the inverter coolant?
    I also watched your transmission oil change video. Do you know the part numbers for both filler and drain plug as well?
    Thank you. I have 2013 prius V two.
  2. Mendel Leisk
    40,809
    Dealership parts department can determine that, and procure/sell. The associated washers too, which are recommended to be replaced. Those plugs (aka drain bolts) don’t need replacement normally; yours are damaged?
  3. Brian1954
    Brian1954 Senior Member
    1,912
    758
    South Central PA, USA
    #23 Brian1954, Aug 22, 2023
  4. melvinpriusv
    2013 Prius v wagon
    Thanks for the info. I just want to have them on hand if something goes wrong. I contacted a local toyota dealer but havnt got a reply yet.
