2010 (3rd gen) wheels compatible with 2016?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by srivenkat, May 12, 2019.
  1. srivenkat
    srivenkat Active Member
    596
    93
    IL
    Hi All,
    It looks like the 2016 (4th gen) uses the same tire size as the 2010 (3rd gen). Is the bolt pattern the same as well? The reason I am asking is if I would be able to use my winter tire/wheel combos on the 4th gen Prius.
    Thanks.
  2. Mendel Leisk
    42,062
    I'm 99% sure yes.
    One minor difference, probably not relevant: third gen and fourth gen rim centre bores have a centre cap retaining groove that varies, means 3rd gen centre caps will not fit properly on 4th gen. Bore diameter is the same, but the internal groove (for centre cap locking tabs) is shifted.
    srivenkat and krmcg like this.
  3. lohikaarme
    lohikaarme Active Member
    337
    338
    NY
    2023 Prius
    Limited AWD-e
    I took the spare from my 3rd gen and used it with the 4th so id say the pattern was the same
    krmcg and srivenkat like this.
  4. JStrenk
    JStrenk Active Member
    203
    101
    Ravenna
    I have my wheels off my 2011 on my 2016 right now. They fit fine.
    It looks like my Gen 3 wheel covers will fit over my gen 4 wheels also.
  5. NicoPriusZA
    NicoPriusZA Junior Member
    Hi there! Any chance you’d be able to post a pic of your gen4 with gen3 wheels? Looking at getting a 2011’s set for my 2016…
