2010- 3x EGR Valves, Preventive Maintenance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Prius_Angie, Jul 24, 2020.
  1. Prius_Angie
    Prius_Angie Active Member
    245
    229
    Saint Louis
    Today's project is a 1 hour maintenance of 3x EGR Valve assemblies. With a quality Capri 1/2" impact driver, I opened up 3x EGR Valves for clean out (with brake parts cleaner, WD40 and Silicone spray) and preventive maintenance. 1:3 EGR Valve assemblies were stuck open; its stem was stuck open due to a large amount of carbon buildup. Pretty neat to see side-by-side the dissimilar views of a normally and malfunctioning EGR Valve assembly. A fully functioning EGR Valve stem can depress and bounce up without any external assistance. The malfunctioning EGR Valve was just stuck open. Using both force and chemicals, I was not successful in fixing nor cleaning out 1x malfunctioning EGR Valve assembly: pliers, degreaser, WD40, etc. The stem nudged back and forth about 3mm but not more. In the end 2:3 EGR Valve assemblies were salvaged and maintenanced.
    P_20200724_102936.jpg P_20200724_103136.jpg P_20200724_103002.jpg P_20200724_104312.jpg P_20200724_104321.jpg P_20200724_104621.jpg P_20200724_105435.jpg P_20200724_105701.jpg P_20200724_105502.jpg P_20200724_104927.jpg P_20200724_104931.jpg P_20200724_104944.jpg P_20200724_104946.jpg P_20200724_105712.jpg P_20200724_105719.jpg P_20200724_105731.jpg P_20200724_105735.jpg P_20200724_105749.jpg P_20200724_105758.jpg P_20200724_104916.jpg P_20200724_110137.jpg P_20200724_110441.jpg P_20200724_110456.jpg
    SFO, Simtronic, Mendel Leisk and 5 others like this.
  2. wheezyglider
    wheezyglider Active Member
    247
    178
    SF Bay Area
    Good stuff. So would you think someone doing an EGR clean could be confident as long as the pintle depresses easily and returns freely? (Not that I wouldn't love an excuse to buy an impact tool :ROFLMAO:)
    Montgomery and Prius_Angie like this.
  3. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    Nice idea with the holes in the plank to imobilize the valve body. :)
    Prius_Angie likes this.
  4. ChapmanF
    19,034
    The end you would be trying to 'depress' for that test is the end you need the impact tool to get to. If you leave the cap on, you have to reword your test to "pintle pulls outward easily and returns freely". But you would be trying to grab and pull a slippery round pintle sitting down in a recess. It's not easy to do. And pliers might mess it up.
    If you could grab it and pull. you would feel and hear a soft whirring of the motor as you pulled the pintle out. You might then need to push it back in also; it has a return spring, but won't necessarily just whir its own motor to return to closed position without a little help from a thumb.
    The 'impact tool' I would recommend for the job is something like the Lisle 62140. It doesn't twist the screws at all, just bonks on them while you gently and steadily turn with a wrench. That's all it takes. The kind of impact tool that imparts a twisting force has a higher chance of breaking one; they're not big screws.
    Mendel Leisk and Prius_Angie like this.
  5. Prius_Angie
    245
    229
    Saint Louis
    that IS the basic takeaway = liberal pintle movement
    i HIGHLY suggest people buy a legit impact driver. If you are undertaking this project, you NEED to be successful in not stripping those 2x screws. If you strip those screws, you have to take more drastic measures to getting them out, or ditch the EGR Valve itself. And those screws sit atop of hardened plastic. Its a bad design, they should've been bolts.
    #5 Prius_Angie, Jul 24, 2020
    Raytheeagle likes this.
  6. ChapmanF
    19,034
    I've had traditional, twist-imparting "impact drivers" for decades, but only got the Lisle seized-fastener remover in the last couple of years. It works on a different principle, where it simply strikes the bolt on axis while you gently turn with a wrench, and it is one of those sort of life-changing tools in the rapid success it delivers with a greatly reduced risk of stripping or breaking the fastener.
    Whoever already has one tool or the other will probably use whichever one they have, but if I were starting and looking for an excuse to buy a tool, it would be the seized-fastener remover for sure.
  7. wheezyglider
    247
    178
    SF Bay Area
    Ah yes I remember now prying it up with a flat blade (and wondering how much damage I was doing). That Lisle set looks nice, they make good stuff.
    And yeah, what were they thinking with that choice of fasteners? Tamper proofing??
  8. ChapmanF
    19,034
    They're just ordinary Phillips screws. I don't think the engineers had any extra goals in mind for them. They're just steel threaded into aluminum that gets hot, and they get very happy where they are.
  9. Mendel Leisk
    42,355
    If you could determine the dimensional details of those screws it would be very useful; you could replace them with a regular hex bolt, or torx socket. I'm guessing they're M5, coarse thread, about 16 mm long??
    The simplest way to sort all of this out: take one of the valves to hardware store, try a few metric bolts for fit.
    #9 Mendel Leisk, Jul 25, 2020
    Prius_Angie and Raytheeagle like this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    That's exactly what @m.wynn did:).
    A novel idea and functional(y).
    SFO, Prius_Angie and Mendel Leisk like this.
  11. Mendel Leisk
    42,355
    Can you recall what they turned out to be?
    Maybe he'll see your flag and chime in.
  12. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    That was about 3 years ago. I've slept since then:sleep:.
    But he sent me a pic:):
    He's the outdoors type, so those are titanium bicycle water bottle bolts and a #10 washer;).
    Use whatcha got(y).
  13. ChapmanF
    19,034
    Or just bonkity-bonk the originals while loosening, they come right out.
  14. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    That's what I've done about a dozen times, but there are solutions out there for those looking for alternatives(y).
    SFO likes this.
  15. Prius_Angie
    245
    229
    Saint Louis
    Great idea-- why should I settle. Added to my task list (when convenient). Thanks.
  16. Prius_Angie
    245
    229
    Saint Louis
    For this procedure, I think your Lisle hammering tool is a better over my impact driver. Not all of my screws came out UNSCATHED. Its only a matter of time those screws get eaten up by the Capri impact driver. I think RTE's idea of a hex bolt is a better longer term fastening solution
  17. Mendel Leisk
    42,355
    Maybe a very thing application of anti-seize too. I have an old toothbrush that's just sorta anti-seize "contaminated": I'll brush threads with it, just gives them a hint of anti-seize.
  18. Prius_Angie
    245
    229
    Saint Louis
    aha, those look nice and fancy. I don't see this assembly being regularly maintenance but ~once/50,000 miles. New sturdy bolts should hold fastening integrity and should grant easy access & a quicker maintenance process. Thanks.
  19. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Readily available if you have a water bottle on your bike and have some washers laying around:).
    But once every 50k miles is what our old 2010 was on before we parted ways;).
    I'll check out our Primes EGR circuit at 120k miles like I did our old 2010. And that circuit will not be as easy to access:cool::
    00556446-6345-4E98-B9BA-9C0E2BF28B9A.jpeg 1515A1AF-0CD3-4ABE-9F01-BFFC238E6D3D.jpeg 8A2916BF-957D-43F1-8E30-82D83A5986FD.jpeg
    Not as simple, but worth the data and piece of mind(y).
  20. Prius_Angie
    245
    229
    Saint Louis
    Sounds like a good idea; I'm a big fan of lubricating everything (where possible). On the pintle threads under the black cap, I placed an ample amount of white lithium grease.
