2010 ABS Connector
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mrmxyzptlk, Nov 7, 2020.
  1. Mrmxyzptlk
    Mrmxyzptlk Junior Member
    Atlanta
    I have a 2010 Prius that is showing ABS, traction control, etc. warning lights. The dealer said it needs new front speed sensors and a new ABS actuator so I figured I'd replace the front sensors and see if that fixed the issue since the dealer wanted $900 to replace them.
    The left front connector is damaged and needs to be replaced. Does anyone have a suggestion for a source for a pigtail?
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Directly solder into it
  3. ChapmanF
    18,940
    Can you describe the damage to the connector at all? Looking at that sensor, it has quite a long pigtail and looks like the actual connector would be pretty out-of-the-way and protected from damage.
    If the damage is confined to the sensor and its own pigtail and connector, you can just replace the sensor. The Toyota one is $200-ish and aftermarket replacements look to be $20-ish. I don't know how good they are, but it's not a super complicated part. The brake ECU has an extra-sensitive sensor test mode that the repair manual tells you to use after changing any wheel speed sensor, though I see a lot of posts from people who have skipped that step. If a $20 aftermarket sensor shows no problems in the special test mode, I would say it's probably good to go.
