2010 Cheap Semi-Permanent Bumper Repair
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Prius_Angie, May 28, 2020.
  1. Prius_Angie
    Prius_Angie Active Member
    245
    229
    Saint Louis
    I'm fixing up the front bumper to this newly bought $1000 white beat-up 2010 Prius with 298,000 miles. The former owner said he spun on ice and hit a road barrier. A lot of work to be done to get back on the road. A new bumper will cost $300-600. Since its already broke, I have nothing to lose with: washers, twist ties, trim clips, and vinyl poultry netting.
    P_20200216_145514.jpg P_20200216_145537.jpg P_20200216_145548.jpg P_20200216_161328.jpg P_20200216_161331.jpg P_20200216_220715.jpg P_20200216_220728.jpg P_20200216_221326.jpg P_20200216_221334.jpg P_20200216_221340.jpg P_20200216_202055.jpg P_20200216_221411.jpg P_20200216_202103.jpg P_20200217_144235.jpg P_20200217_144242.jpg P_20200217_141021.jpg P_20200217_144225.jpg P_20200217_142555.jpg P_20200308_083804.jpg P_20200308_104534.jpg P_20200308_104539.jpg P_20200308_104550.jpg P_20200216_220316.jpg P_20200217_140958.jpg P_20200217_141116.jpg
  2. 2014
    2014 Member
    30
    31
    MA
    Buff the scrapes off and it will look even better. Might hold up for a long time if the plastic is not brittle and the ties don't rip through. Good enough. Well done.
    Prius_Angie likes this.
  3. Mendel Leisk
    42,364
  4. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    Really well done! If you're looking to take it to the next level, you could try reinforcing the washer attachments with epoxy (JB Weld is my favorite). Then you might try some Bondo to smooth over the especially cracked and zip-tied sections. Finally some Plasti-Dip to paint the whole bumper. Be aware that although paint will make things look better from 10+ feet away as the color becomes uniform, at closer viewing distances it will look worse since the variations in texture + shape become more visible.
    And if you have a junkyard nearby, you could always check for a whole "new" bumper.
  5. Mendel Leisk
    42,364
    There's a staple gun that heats up the staples: when you apply them they melt into the plastic. For body shop though: pricey/tricky?
    I used this stuff once:
    https://www.canadiantire.ca/en/pdp/bumper-repair-kit-0475601p.html
    I continue to use just the fiberglas mesh, with two-part epoxy, now and then. Pretty much always for the first black underpanel piece, directly below the front bumper: it's so low it ALWAYS snags concrete wheel stops. And it snags, just about rips itself off the car every time you back off. I'm cagey now, never use the wheel stops, stop a little short. Well almost always.
    That something like this happens is a Toyota fail: the wheel stops are pretty much the same the world 'round, should not have passed testing phase.
  6. Prius_Angie
    245
    229
    Saint Louis
    thanks, it was a very fun project for me, particularly as I didnt know where the bumper was going to end up: renew or new purchase. Only plan I had was a budget limit to not exceed$ cost of a new bumper: new $35 under splash guard, bunch of zip ties, washer, etc.
    Im doing the EGR valve swap now, as the part just came in the mail yesterday. This is the last procedure needed to get back on the road and inspected. If this holds true and the car lasts longer than 6 months; I shall definitely consider doing some beautification upgrades. Thanks for the great ideas.
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I'm going to say from description of repair approach and 1st picture to last picture, that looks a whole lot better than I would of ever thought possible.
    That being said, it's reminds me "Young Frankenstein" because it's still Frankenstein in a Tuxedo.
    But you brought the bumper far more to life, with washers, twist ties, trim clips, and vinyl poultry netting than I would of thought possible.
    For as described, "Semi-Permanent" bumper repair? I have to say good job.
  8. Prius_Angie
    245
    229
    Saint Louis
    Good to hear this bumper repair garnering some interest.
    Im adding more pictures for your entertainment-- enjoy.
    You will notice I mixed up use of twist ties and trim clips where possible. The accident made it more challenging for anchoring and stability.
    ;) For good measure, Im gonna add a handful of extra zip ties in the glove compartment.
    "Frankenstein in a tuxedo" --- indeed.
    P_20200530_120245.jpg P_20200530_120146.jpg P_20200530_120208.jpg P_20200530_120254.jpg P_20200530_120337.jpg P_20200530_120722.jpg
  9. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    I've watched a few video's of places that melt plastic on messed up bumper covers like yours.
    They do a great job of putting back together, melting the plastic just right, sanding and painting it.
    They look brand new! Good Luck with yours!
