2010 - Check Hybrid System (p07E8) Hesitates/Stalls when Accelerating
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by samsonite22, Oct 5, 2021.
  1. Brian1954
    Brian1954 Senior Member
    2,694
    1,077
    South Central PA, USA
    I just checked my manual and there is a light of a battery. It is the charging system warning light. Is this the light that comes on (see PDF attached)?
    I wanted to correct myself.
    #41 Brian1954, Feb 5, 2022
  2. samsonite22
    samsonite22 New Member
    25
    Chattanooga
    Sorry I forgot to respond to you. I get the whole "Check Hybrid System" warning. Not a small battery warning light with battery or just a check engine light.
  3. samsonite22
    25
    Chattanooga
    6 months later and my car is still running fine, maybe better. I reset the CEL probably once every 3-4 days, sometimes longer. No misfires. Each time I crank it, I make sure I give it about 2 minutes to warm up. Engine kicks in, then usually 1:00 minute - 1:45 later, it turns off and it's just electric battery.
    May re-clean the intake manifold soon just for fun (jk, for maintenance).
