2010 codes: C1203, C1336, C1345, C1393
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ItsDave, Aug 10, 2023.
  1. ItsDave
    ItsDave Junior Member
    29
    Long Island
    Just got a laptop from ebay and a cable from tacrix. Going to get a 2 day sub at Techstream this weekend. Since I’m trying to resolve this in this those two days I’m hoping someone here can suggest where to start. I’m thinking it’s a brake position sensor? Posted this on another forum but no replies there:
    Plugged an OBD2 scanner in while the car was running, soon as I did all the brake light warnings and traction control light came on and I can’t clear them, regenerative braking is gone, just regular brakes now. Lesson learned, have the car off when plugging in. What did I fry? Where to begin with this many codes?
    C1203 - ECM communication malfunction
    C1336 - Zero Point Calibration of Deceleration Sensor Undore
    C1345 - Linear solenoid valve offset learning undone
    C1392 - zero point calibration of stroke sensor undone.
    Won’t have time to look at it until the weekend, but I would be very grateful of ideas on where to start Thank you!
    edit - Title should have said C1392 not 1393 can’t seem to change it
  2. Tombukt2
    Tombukt2 Senior Member
    13,821
    2,507
    Durham NC
    I'm having similar codes to that ECM malfunction gateway issues etc I'm looking at replacing the blue box that's right behind the upper glove box this weekend looks like a few people have done that and some of the tests in TIS the last part of that section they talk about replacing that blue gateway box the ECM itself and something else I will get all three parts off of 08 this weekend so I can swap them around take them apart look inside my originals for any traces of corrosion arcing something this just came out of nowhere actually right after I wash the car I bought the car the night before brought it home sat in the driveway overnight It was running when parked came out that mid-morning move the car with no issue put it in a sunny spot where I was going to clean the trunk hatch area that gets all clogged with leaves and tree debris and do the front cowl and wiper area that was kind of getting full of the same junk right after I got done washing and cleaning I don't think I flooded the car per se. The red triangle and all the lights lit up talking about the high voltage battery voltage crossing over into the low voltage area that's not happening according to my test meter and checking the bolt to battery case steady 114 and not moving. That ECM and gateway has got something to do with a lot of this non or miscommunication It looks like in my case anyway.
  3. ItsDave
    29
    Long Island
    Did you have any other codes? Also is that a gen 3 you have?
  4. Tombukt2
    13,821
    2,507
    Durham NC
    Actually this is happening right now on an '08 generation 2 but the codes are similar and the problems are very similar as far as this communication business and gateway go I don't know if the computers are exactly the same looking and in the same location but very similar readout and things and lights happen when these conditions are met I'm dealing with this right now and yes I have a lot of b codes in TIS the two main codes are the communication with the air conditioner and the leakage of the HV battery voltage to the rest of the car which as far as I can tell measuring at the battery plugs bolt to the case of the battery is not the case. And when I look up the repair procedures for that leakage at the very end of that procedure if you have the NG as you're going through the process the last page talks about replacing the blue communications computer and the ECM which would be quite costly if you were buying Toyota parts probably enough to put the car down
    ItsDave likes this.
  5. ChapmanF
    18,964
    Might not have fried anything. Sometimes a glitch on the network while you're plugging or unplugging a diag tool will cause a bunch of errors and lights; it has happened to me when I was using a cable made with cheap, unplated pins. Sometimes, the codes will mostly go away after unhooking the 12 volt battery for a while. (Then you have to reset various forgotten things, like clock, radio presets, steering angle if you have the advanced parking, etc.)
    If the brake codes for unlearned solenoid offset or stroke sensor keep coming back, then you'll have to go through those learning dances.
    ItsDave likes this.
  6. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    that's what I'm having right now /
    So, what procedure do I have to go through to get that thing going again?
    I tried the re-learn thing with techstream but it's not doing anything (it said it is, but the fast flashing lights never showed up) /
    (Possible it's not doing anything because of the cable (9 years old, some things didn't work from the beginning on))?
      File size:
      154.1 KB
    #6 StarCaller, Aug 11, 2023
    ItsDave likes this.
  7. ItsDave
    29
    Long Island
    I’m hoping that’s what it is. People have said plugging the obd in while the car is in shouldn’t cause any problems, but the timing of it is suspicious to me because it happened as soon as I plugged it in. Hopefully I’ll get lucky
  8. ItsDave
    29
    Long Island
    I can let you know tomorrow if the Tactrics cable works
    StarCaller likes this.
  9. ChapmanF
    18,964
    You've got the evil C1451 code. You'll have to successfully complete the ECU's brake bleed procedure first to eliminate that code before anything else will work.
    After that, the solenoid offset codes will usually be taken care of, or you go through that separate procedure then if they haven't.
  10. StarCaller
    1,284
    733
    brake bleeding is not working for whatever reason /
    pretty much instantly after I press the last next button it says that it failed /
    ItsDave likes this.
  11. ItsDave
    29
    Long Island
    Just reporting back, the Tactrix cable seems to work fine. You were right Mr Chapman, must have been a glitch because I was able to clear all 4 codes with the Techstream and had to buy no parts.
    After clearing all DTC’s, 1 went away and 3 came back. I did a couple of relearning procedures as per the manual and the ECM circuit one went away on its own.
  12. ItsDave
    29
    Long Island
    Just trying to help out before I have to run out in a few. I'm not too well versed in this stuff, but found a thread where someone also kept failing their brake bleeding until they hooked a trickle charger up while they did it. Also, they were removing the wrong ABS relays the first time they tried. Apparently a 100% battery is a must while you do this:
    Techstream ABS "Air Bleeding Has Failed" | PriusChat
  13. StarCaller
    1,284
    733
    I had a batteryMinder connected .
    Tried it again this morning - same thing /
    I'm going to order a Tactrix cable & hope it'll work /
  14. ItsDave
    29
    Long Island
    Yeah, kind of a craps shoot with the cables unless you spring for the $500 mongoose one.
  15. ItsDave
    29
    Long Island
    Whoops double post
  16. StarCaller
    1,284
    733
    got the Tactrix cable --> same thing / :(
  17. Bankai319
    Bankai319 New Member
    2014 Prius Plug-in
    Did you find a solution? I’m having the same problem it’s driving me insane
  18. Tombukt2
    13,821
    2,507
    Durham NC
  19. Tombukt2
    13,821
    2,507
    Durham NC
    Did any of you manually bleed the brakes yet The fronts have no air The rears have no air in the lines everything's dripping or running or squirting clear pretty much? If that's done what lights do you have on now or codes usually after I bleed manually everything is either working pretty much properly or I have lights Christmas tree up because the used brake actuator I'm using is also bad.
  20. Bankai319
    2014 Prius Plug-in
    codes c1203 and c1345 wont go away when trying to erase them with techstream.
    Abs, brake, (!) and vsc lights are on all the time and stay solid when doing the 120seconds valve offset solenoid learning instead of blinking.
    Both accumulator and master cylinder are brand new, bought them on toyota dealer site with vin verification to make sure to get the right parts.
    Car wont go in invalid mode after doing the brake pedal dance (but would go in invalid mode easily before parts were changed).
    I did bleed the brakes manually with techstream plugged and followed the steps, and couldnt see any air bubbles even after using maybe 2/3 of a big brake fluid bottle for the rear and 1/3 for the front but will do it again to be sure.
