2010 Coolant Temperature Sensor
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by David Noyes, Apr 17, 2024.
  1. David Noyes
    David Noyes Junior Member
    Irvine, CA
    PLEASE HELP! In my 2010 Prius that has over 257,000, mi, The coolant temperature sensor keeps coming on and going off even though the temperature is staying well within the parameters between 85 and 100 c. I replaced the coolant pump the fans are working fine. I replaced the thermostat. I did a coolant flush! I "burped" it... Putting it in maintenance mode and letting the air release for a good hour one day. The only thing left would be the temperature sensor, but a mechanic I know says it's reading the correct temperature!?? There are no codes and it happens intermittently. For all practical purposes, my car is working great. There's no power fluctuations, my air conditioner works fine and my mileage is fantastic. Please help me! One final reminder it is not actually overheating by any standard metric...
  2. Tombukt2
    Tombukt2 Senior Member
    13,823
    2,509
    Durham NC
    So then more than likely the temperature sensor is acting up and lighting the dash at inopportune times or there is an air bubble still in the system once it gets around that sensor the sensor sets the light if this is what's happening usually a few days of driving works the air out I don't know how often this car sits or how much. Usually when you do this you fill up to that b mark or whatever it is it's above full then you drive around and when you get finished it should be at the full mark when you're done or a little below it and you top it up. So if it's not air and we know it's not air and that's what we're standing on then the sensor must be acting up whenever this happens I guess electronics usually don't act like this but I guess anything could be possible If I know my car is not overheating by any metric smell temperature gun etc I would probably keep driving after looking at this other p code I'm working on now it seems like wiring harnesses and things can get fubar really quick in these cars I'm dealing with a p lock code that may have this problem but it has nothing to do with this here but possibly wire damage that's affecting not being able to actuate park.
  3. Brian1954
    Brian1954 Senior Member
    2,667
    1,066
    South Central PA, USA
    Do you mean the high temperature warning light comes on?
    How long have you owned the car?
    Has the engine ever been replaced?
    Has stop leak ever been put into the engine coolant system?
    Where did you buy the engine coolant pump that you installed?
  4. ChapmanF
    18,975
    There are two engine coolant temperature sensors, and many sensors for the (completely separate) inverter/transaxle cooling system. With Techstream or some similarly-capable scan tool, you might try to datalog those readings while you drive for a while, then see what they all were when the warning light came on.
    The engine temperature sensor in the cylinder head is an "Engine and ECT" PID. The one in the EHRS return hose is a "Combination Meter" PID. The ones for the inverter/transaxle are "Hybrid Control" PIDs.
  5. David Noyes
    Irvine, CA
  6. David Noyes
    Irvine, CA
    I know this is weird, but I didn’t see this reply when it happened in 2024. I am having the same problem. The engine has been changed the temperature System light goes on and off intermittently but when this was happening, I was monitoring the temperature and it was perfect! I drove 800 miles with this happening. I mean consistently 800. The engine still runs fine. I had a Toyota technician look through it the water pump is fine. There are no codes and the temperature is consistent. No engine noise no leakage tentatively nothing’s wrong but it’s really really hard to keep driving it and ignoring the light. Help please if anybody has run into this please advise me. Thank you.
  7. ASRDogman
    ASRDogman Senior Member
    8,052
    4,083
    Have you checked the inverter pump?
    How did he check the coolant pump? With a scan tool you can check the rpm's
    If it's the engine that it's lighting, the pump might not be working correctly.
    You can check the resistance of the two temp sensors. You may also have a sticky thermostat.
    Check the condensor/radiator, make sure they're not clogged.
  8. Brian1954
    2,667
    1,066
    Did you read post #4?
    The coolant temperature warning light on the dashboard can be activated by two different engine coolant temperature sensors. Which engine coolant temperature sensor have you been monitoring? What are you using to monitor the temperature?
