2010 engine ticking noise, need ideas
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Nathan Barbary, Aug 3, 2021.
  1. Nathan Barbary
    Nathan Barbary Junior Member
    Technology
    So within the last few months I've noticed that my engine now ticks.
    2010 prius
    225,000km
    No coolant or oil loss (knock on wood)
    EGR / intake system cleaned
    New plugs, pcv
    Occ installed off pcv
    CVT fluid changed
    Mobile1 0w20 oil
    I've owned the car a couple years now and never noticed it before until recently. At my last oil change I put in some royal purple 0w20 instead of my normal mobil1 and an oil additive to help rejuvenate the engine (snake oil science)
    With the pandemic the car has gone from driving 1000km a month commuting to maybe 25-30km a week of errand running, short trips. I recharged the A.C. and I sound deadened the interior recently which is when I noticed the ticking.
    Symptoms:
    -Engine starts normally, no rough starting ever.
    -After a couple seconds the engine Will start to tick, tick matches rpm.
    -When I'm parked and rev the engine slightly the ticking will quiet and it sounds normal, when it goes back to idle it starts ticking again
    -while driving it will tick under load or acceleration, more noticeable the harder I accelerate, still matches rpm.
    -with the windows closed, and driving I can barely hear it if the radio is off. Windows open I can hear it when the sound bounces off the environment.
    -if I take it for a longer drive and get the engine good and warm, I feel like it's less noticeable.
    Additional info:
    -I changed the royal purple oil out for mobile1 at 1000km and added some liqui moly hydraulic lifter additive as well as liquid moly jectron fuel system cleaner. I've driven it about 200km since doing the above and haven't noticed any major change in the tick.
    -The oil I pulled was clean, no signs of contamination and the coolant levels haven't budged.
    -Fuel economy hasn't changed, still sitting around 5.0l/km.
    -No dtc's or performance changes.
    I've read that the 1.8l has hydraulic lifters and shouldn't normally tick, they're also a pain to adjust/replace.
    I also don't know if it's my valvetrain or my injectors because both can be noisy.
    Is there anything easy I can do to try and further troubleshoot the noise? Like pulling the Valve cover and checking for play or running higher octane fuel or replacing my vvt solenoid or knock sensors?
    Or
    Should I even bother pursuing this further and just accept that my car ticks now?
    Any gen3 gurus have wisdom they're willing to share?
    I'm not afraid to get dirty and have plenty of mechanical acumen and tooling to resolve problems that don't absolutely require a professional touch.
  2. QuarterMileAAT
    77
    33
    NorCal
    Following as I have noticed a tick as well with my ride.
  3. ChapmanF
    18,969
    If you think the 2ZR's hydraulic adjusters are a pain to replace, just try doing a valve adjustment on a 1NZ's solid lifters!
    The beautiful thing about hydraulic adjusters is there really isn't any adjustment to do. If one stops behaving as it should, you just replace it, and all 16 are the same, none of the 35-size select-fit business as with the 1NZ. I guess you do need the camshafts out for access, but that pretty much goes with the territory.
    I haven't heard of them going bad much.
    Have you localized the ticking to the top end, with a stethoscope or such?
    You say it goes with RPM ... are you positive it goes with RPM / 2, which would clearly make it a valve issue?
    I can't really count fast enough to make that judgment by ear (maybe if I trained myself and did it all day, I could), so I would probably record it, and then look at it in Audacity or something. If I used a channel for the cam position sensor, I'd probably even know which valve (ok, which two valves) before taking any covers off.
    During my EGR cleaning project, there was a little bit of driving I did before putting the cowl and wipers back in. That changed the engine compartment sound noticeably from in the cabin, and made me aware of tickiness that I never noticed normally. Your recent change to soundproofing could have had a similar effect, in which case maybe it's no big deal.
  4. wheezyglider
    wheezyglider Active Member
    247
    178
    SF Bay Area
    You might try putting the Prius in maintenance mode to keep the ICE idling while you use the time-honored methods of locating an engine noise source. (For example touching a long screwdriver to various points and listening at the handle, or using a length of tubing with a funnel as the ear piece -- essentially DIY mechanic's stethoscopes.)
    Edit: plus whatever Chapman just said!
  5. Nathan Barbary
    Technology
    I haven't localized it to the top or bottom. I don't have a stethoscope or have I ever used one so even if i did use a method to isolate the noise i'm not confident enough to know what I was hearing.
    I've only theoretically isolated it based of dohc head design.
    When i said that it matched the rpm that was a poor categorization of the symptom. I think a better way would be to say that the ticking follows the rpm in a linear. 1 tick per rpm/2 which would theoretically indicate a problem with a lifter.
    That being said if we were to assume that I did have a bad valve adjuster.
    1) it's quite an involves process to access them for replacement, can they be cleaned or replaced without removing the cam?
    2) if I'm going so far as to remove a cam I may as well go further and replace all the lifters, headgasket and water pump and leak check all the valves because it's only a few more bolts at that point. I'm not super keen on doing that unless I need to.
    3) other than being noisy, is there any real harm in just leaving it and trying to clean the lifters by running some engine flush through or other such chemicals?
    4) can I pull the Valve cover and try cleaning the lifter pathways with a bit of brake cleaner and some dental picks?
    5) taking it to a shop is kinda out of the question because shop rate for a valve inspection is 8hrs which is a huge coat with parts.
    Should I just accept it ticks will any real harm come to the engine with a noisy Lifter?
  6. ChapmanF
    18,969
    I'm not a big proponent of the "might as well replace everything" philosophy, though I've certainly had it pushed on me by parts vendors for some reason. The hydraulic adjusters are $30 each and if fifteen are fine and one is leaking?
    Going on to head and head gasket is more than a few more bolts. At that point you're also into the timing cover, and when that goes back on it's a mission-critical form-in-place-gasket operation that you have something like three minutes to do right.
    Were you really able to count that fast? Or match it by ear to a pulse generator set for rpm/2, something like that?
  7. Nathan Barbary
    Technology
    I loaded a metrognome set to 500 bpm and it sounds really close to the engine at idle. This is an approximation by ear.
    I don't want to replace everything but if I need to remove the cam, then I need to remove the timing cover to disconnect it from the chain sprocket. So if the cam is removed, the extra cost to so all the lifters would be justified if it means I never have to remove the cams again for the life of the vehicle.
    I was exaggerating when I said a few more bolts, I've got 3 young kids so if I'm tearing my engine apart it's going to take a lot of time to do. To me it's less overall time to go all the way to the head gasket if I've got the timing cover off then to just do a valve adjuster and then have to do the whole process again another time for something else. It's really more of a personal assessment of how much time I can devote to tearing engines apart.
  8. ChapmanF
    18,969
    Nice approach.
    Maybe?
    I am accustomed to being able to wire chains to sprockets and get them off cams without disturbing timing covers, but I have to admit I've had no occasion as yet to try that on a 2ZR.
    Edit: yeah, sure looks like a tall order in this case.
    #8 ChapmanF, Aug 5, 2021
  9. Nathan Barbary
    Technology
    I would likely go so far as to try a stethoscope to approximate the tick and remove the Valve cover to visually inspect the valvetrain for signs of obstruction or damage as its involved but could be done in a couple hours. Beyond that it's a major time investment if I couldn't remove the cam without removing the timing cover, wirelocking or otherwise.
    This would leave me with the option of living with it until something else goes and trying various other cleaning methods like engine flushes or seafoam or different grade oils to try and dampen the noise.
    Is a noisy lifter worth all the hassle of fixing or can I leave it and not worry about it? I've read about all kinds of engines that have noisy lifters and it's just universally accepted as a nuisance that comes with high mileage engines.
    Thanks for your input and help Chapmanf. I do appreciate it,
  10. Nathan Barbary
    Technology
    I've come to an interesting bit of progress on my ticking problem.
    After throwing some money and a couple days of wrenching at this problem, I've discovered that i may not even have a lifter issue at all.
    So after the world's most expensive diy oil change.
    Royal purple 0w20 (1000km)
    (Fram ultra synth filter)
    Mobil1 0w20 (300km)
    Liqui moly hydraulic lifter additive (200km)
    Liqui moly engine flush
    Motomaster 0w20 (flush out engine)
    New fram ultra synth filter
    Liqui moly 0w20
    I've discovered that i have a small hole in or around my cyl#2 exhaust manifold. I noticed it while cleaning off my timing cover seepage during my oil change party.
    It's not definitive but I have to fix it before I can further diagnose this issue. It would make sense as the tick would get louder and quieter depending on the load and rpm of the engine. It is possibly not a tick at all but a leaky exhaust manifold on 1 cylinder.
    Larryy likes this.
  11. Michaelreyn
    Michaelreyn New Member
    Oklahoma
    2014 Prius c
    So was that exhaust issue the fix?
  12. Nathan Barbary
    Technology
    Yes. There was a pinhole leak about 1/8" in the #4 cylinder exhaust manifold pipe. Once I got it changed out the sound went away. It took 3 different exhaust flanges to get the manifold to seal properly to the catalytic converter but the sound is gone
    Larryy, violinguy and Mendel Leisk like this.
  13. Larryy
    Larryy Active Member
    104
    113
    florida
    I posted a couple times regarding my 2007 ticker and no one seemed to have a definitive answer for this problem. I decided to ignore it and if the engine g'norked, I'd just replace it. Well it's been over 2 years and more than 15,000 miles. I would think that if it was anything mechanical, I'd have a new engine by now. Recently I started thinking "exhaust leak" but haven't taken the time to investigate yet since it still goes. However, a few months ago I was in the parking lot of a Publix supermarket in Florida when a cute blonde haired gal altered her course to the store's front door to come tell me to "put some oil in that damn thing!". I am glad to know that my suspicion is probably right. I will be investigating this. Thanks Nathan
    I do have a bigger problem revisiting me, my New Prius Battery is not cutting the mustard any longer. It was half the price and it lasted roughly half the life of an OEM. I'm still using it but I have an old cell phone with Torque Pro permanently hanging on the storage compartment door under the radio so I can reset the Hybrid Battery OBD codes on the fly to keep it out of limp mode. It doesn't happen much while running at highway speeds, but as soon as I slow down they pop one after another. Aggravating, because it happens most when in traffic. It's a solid rust free Florida car so I'd hate to junk it. I'm back in Michigan and looking for a used pack from a wrecked or rusted northern gen 3, any tips are appreciated.
  14. Larryy
    104
    113
    florida
    Well. I just crawled out from under and found no exhaust leaks and a nice clean, nearly rust free exhaust header. I put the car in maintenance mode and ran it while I listened to everywhere I could reach with my mechanics stethoscope. The tick seems to be coming from everywhere and definitely gets louder when load is increased, as in going from neutral to drive. I then removed the air cleaner and reconnected it with a PVC 45 deg elbow so the MAF would still work. Then, with the engine idling, and ticking, I unplugged the injectors one at a time and low and behold, when I got to cyl #3, the ticking stopped. I plugged the connector back in the tick came back. I repeated this multiple times with identical results. This is a classic indicator of piston slap. Yes, I know no one wanted to hear that. The almighty Toyota succumbing to piston slap. So it's not only the junky Jeeps and failing Fords whose pistons slap harder than the world's best bass players. The good news is, most engines will slap for a long time, like my Ford 302 did.
    Worst case scenario for the future, the piston crumbles and the rod reconditions the cylinder. Then here comes the junkyard engine. I had that happen in a Ford 300 straight 6. I replaced it with a Chrysler 400 v8. Ah, the good ole days when we didn't need 50 mpg.
  15. CR94
    CR94 Senior Member
    2,822
    1,238
    Northwestern S.C.
    How many miles has it been doing that? My '72 Subaru piston-slapped when cold the entire ~190k we had it.
    Have you mentioned this discovery in a 2nd-Generation forum?
